Accumulator
Well-known member
Only thing I can figure is I’ve got a much stronger upper body...
You`re sure not alone there
I like DOMS as long as I’m not really over stressing the muscle.
Yeah, I readily admit I overkill things going for that. Probably contributes to my need for such long recovery periods between workouts.
The calf stuff I don’t do much of anymore, I get plenty of calf work in doing squats and dead’s.
Hey, that`s interesting! I *NEVER* feel my calves after Upper Leg work, never. Funny how well mine respond to just two-three sets every few weeks...that`s a big part of how I stumbled across the realization that (gee, Mentzer was right..) I was overtraining. People complimented my Calves of all things and I`d never prioritized them!
The guy is a fantastic motivator that for sure.
Great that you have a training partner that you synch with. Many people get a *LOT* out of that, it really helps `em get in good workouts...lucky you!
Agree on the pull ups. I do sets of 6 as that’s all I can crank out currently usually 4-6 sets of them.
I wonder what`d happen if you only did, say....two sets of `em per workout. One with the torso basically perpendicular to the ground and the second leaning back at an angle. I`d do the second set with a parallel grip so you`re a little stronger (even if the Bis/Brachs are responsible for that). Heh heh...jrock645 is probably thinking "there he goes with the minimal workouts again!"
They are always the first back movement due to the fact I haven’t fatigued the muscles yet.
Yes *yes* *YES*! Exactly the same here.
I generally vary the grip but usually shoulder width palms facing one another or wide grip palms facing away from me.
I found (again, to my surprise) that the wide grip...which I thought would be "good for the stretch"/etc. wasn`t really *productive* with regard to getting bigger/stronger and might`ve been working things other than my Lats. I found that a slightly narrower-that-shoulder width grip produces the best results for me but maybe that`s just me. Had to basically force myself to do those instead of doing "one wide, one more narrow" etc. where I was doing quite a few sets telling myself "they`re all different". It was another case of what I read/believed was best, and what sure felt right, just wasn`t really right for me.
If you do the Pronated/palms-down ones first your back will get the biggest stimulus while it`s fresh and strong(est). I`d definitely go a bit narrow when doing the neutral/palms-facing ones.
Note that adding in some *unilateral* Lat Pulldowns can be incredibly beneficial. When both arms are working (Pullups/normal Pulldowns), the muscles can`t optimally contract because they "bump into each other" when both sides of the back are contracting. You can get a much better ROM in the contracted position by doing one arm at a time. Determining the resistance for those...light enough that you can really get that FULL ROM, can be another of those humbling experiences that has dummies wondering why you`re bothering with "those baby weights"..(they`ll also wonder why your Back is better than theirs
All done with just hanging body weight with full ROM.
OK, I`ll spare you my "Optimizing additional resistance with Pullups and Chins" lecture
Full arm extension to full contraction with chin above the bar. They are working wonders. Focusing on pulling my elbows through my hips really fires the last and I’ve seen great gains there.
That sounds great! No surprise that they`re working wonders for you. That *really* has me wondering how it`d go if you added in the unilateral Pulldowns..
One thing those allow you to do that`s tough to accomplish with Pullups is that you can rotate your hand from neutral at the start to supinated/palm up at full contraction. That`s part of what allows for an increased ROM and it makes you a bit stronger (even if it is partially Bi/Brach involvement) after having worn yourself out with the Pullups. BTW, this "rotate the hand from neutral to supinated" really helps make (unilateral) Cable rows more productive too (rows are another movement where doing both hands at once limits the ROM at contraction..but I still do one set of BB Rows anyhow as my first Rowing movement). Wish I had some rotating handles I could attach to the Pullup Bar so I could do it with that movement too.
So glad you`ve figured out that "elbow orientation" feel, really good for the Mind Muscle Connection.
