2007 Range Rover HSE Restorative Correction
autoconcierge
Recently completed job in the shop, this Pre-owned vehicle was picked up by a new client as he sought me out to bring this vehicle back to the condition he wanted it to be. The vehicle had the usual issues a dark colored finish will experience in being a 2007 model year, the lurking problem was .............................hard water etch!!!.
As I seem to get vehicles like this more and more(Reputation established for correcting this awful problem) there would be over 50 hours spent total to correct this issue along with the correction and thorough cleaning of the entire vehicle..
After a thorough wash/decon I set about to correct the finish and started with the back gate area first as it was the area with the most difficulty with the factory lettering and tight confines.
Example of the marring on the finish.
There was a beautiful finish under there after all.
Working around the lettering was tedious as the option to remove them and re-apply a new set was not a option.
Another thing to attend to was one of the wheels was curbed, so the solution was to replace it with the pristine spare wheel, so I removed it and had my neighbor Alek from Alekshop dismount the tire and remount the tire from the damaged wheel.
Roadforce balanced.
New wheel mounted and torqued to factory spec(103ft/lbs).
Next task was to clean up the damaged wheel on the inner barrel before storing the wheel back in the trunk.
Task completed.
Now onto the "Horror" of water spot etch, this vehicle must have been hit with re-claimed water from a sprinkler and then left to BAKE for the next few years until I was able to correct this issue, the damage was everywhere even in the jambs.
During removal of the etch.
Not good.......................................(Understatement).
After.
50/50 on the glass.
Water spot removing gel applied(Mark V Splash).
Damaged rearview mirror.
50/50 correction shot.
Mirror corrected.
Glass polished.
Making sure the finish up top was as nice as the sides of the vehicle.
Hardwater etch removed from all the tight jamb areas and rubber seals.
Vehicle right before LSP was applied.
Job was complted in the evening so no "Sun pics" my infratech light was used to suffice.
Interior was not bad at all..................thank goodness.
Nice work! I am surprised that the interior was that clean.. it seems that most Range Rover owners have a minimum of 2 Golden Retreivers and there is usually enough dog hair inside to make a third! :lol
Looks like a ton of work went into this one. Good job on knocking out all that water spotting, Bob. Major improvement there!
Bob,
Incredible work as always. I called every Autozone in the area and cant find mirror correction cream anywhere. Although I did find a plywood stretcher.
Lotuseffect said:
Bob,
Haha......................at least say something like.............the detail looks nice, btw what was used on the mirrors?....instead of "tell me what you did".....................now.
Incredible work as always Bob! What di you use on them mirrors? How about telling me about the compound you used as well. Man look at them 50/50's, any of the roof? :dance What type of paint was used on them wheels? They all matched perfect. How about them tires? What gets you that nice deep matte finish? Anyways as always Incredible work.
:peace: Barry
barry theal said:
incredible work as always bob! What di you use on them mirrors? How about telling me about the compound you used as well. Man look at them 50/50's, any of the roof? :dance what type of paint was used on them wheels? They all matched perfect. How about them tires? What gets you that nice deep matte finish? Anyways as always incredible work.
:peace: Barry
lmao..................................
