blkZ28Conv said:GM excellent restoration! :bow
Gotta love a Torch Red C5 :usa
This one, my good weather daily driver prepped and protected with Menzerna IP, Z-PC and Z5PRO and Z2PRO, topped with Z8. Wheels protected with old Klasse AIO, SG, Z5 and Z2.
Tire dressing Z16.
Interior: Woolite and Z9 (leather cleaner), Z10(leather conditioner) seats and Sonus dressing dashboard.
mav63 said:Hey Bryan, great job! Do you think you could have remove the swirls with the PC?
You did an awesome job and sounds like the owner is very pleased!
1 Clean WS6 said:Simply STUNNING work Bryan!!! :bow
I look forward to seeing your details and am glad that some of the Posse is finally in good hands...even if it must be kept on the down low.Keep it up my friend!!! :waxing:
Smoked Tails said:Looks great. I can't wait to see how the CJ looks.
gmblack3a said:blkZ28Conv, That looks great!!! I can't wait to give Z5pro a try.
gmblack3a said:Thanks! If you have not worked on C5 clear before a jackhammer is the preferred method of removing defects. I have not had much luck at all on a vette with the PC. IMO no way a PC would cut it on this one.
Gen2 said:Hey gmblack3a, finally you tried out the AJ and the paint sure looks wet :drool:
I would suggest you try not to use AG to remove the residue of AJ because there is some cleaner in AG that might affect the bonding of AJ. You can try using the method Scottwax suggests, using the same applicator pad you used for applying AJ to go over those residue spots that are harder to remove. After that wipe off with a MF towel and in this way the residue comes off effortlessly.
Gen2 said:You are welcome, gmblack3a. I would suggest after you have applied AJ, let it fully cure for 12-24 hours before applying AG over it.
