imported_JoshVette
ricka said:Josh,
Very impressed with the wet sanding results. Does that work as well with rock chips? Always worried about taking off too much clear coat.
Thanks
No, I would not attempt to wetsand chips. Just touch up paint them very lightly and let dry, then buff down.
Wetsanding is really useful when on a scratch or scuff mark not through the clear or primer IF the rotary or PC can't take it out.
If a scratch is through the clear or primer then it is beyond repair, then you can only smooth it down and then touch up paint what's left to make the color match. If the scratch is not through the clear then most of the time the clear can be sanded down to the level of the scratch but even then if it's too deep you'll have issues with getting the sanding marks out.
On soft clear coats this is fairly easy, but on hard clear coats, it's a nightmare.
Josh
