SHICKS said:Well as you can see, just below the silver water line there was some scum, so I was not really doing any harm if I slipped, but no it did not seem to dry white, but kind of make it look damp. I'll check on it in a few weeks. That part is underwater anyway, so no bigge if it is stained.
Accumulator- not sure if you caught the Corvette thread I created, but if you did not check out the horror show the dealer performed on the paint!!! :wall:nervous:
Steve
Shicks
There is a boat hull cleaner you can buy that you can get that will help remove all the scum below the water line. I had to use it on my boat the get a bad oil/fuel/scum stain off of the hull. Most hull cleaners contain hydrochloric acid so you will need to dilute it. Remember to start off very light with the acid and heavy with the water, you can always increase the strength of the acid. Also on a safety note, always pour acid into water and NOT water into acid, this will cut down on the chance of the acid exploding and getting all over you.
On another note, the scum on the hull will cut down on the hot speed and full economy of the boat, so keeping the hull clean is important.
