Snow Foam Lance Test : Chemical Guys Mr. Pink
Re: Snow Foam Lance Test : Chemical Guys Mr. Pink
Thanks, I dig your videos.
Interesting video as I always like seeing foaming.
It kinda reminds me of the video I did that you recently posted to not so nicely on YouTube. http://www.autopia.org/forums/detail...tml?highlight=
What are your thoughts on the soap? Does it work as claimed, does it clean well?
How does the time it sticks to the car effect the cleaning ability vs other soaps?
Quote:
Originally Posted by
Bunky
Thanks for the video.
Pats300zx
Great video !!!
Mary B
:thanks
milky
Awesome video Alfie!
GearHead_1
thank you all :wub:
TroyScherer
dude, you need to change your foam lance to make it foam. you use 2 ounce = 60ml
and i only use 40ml, i get way thicker foam than you
and i use lower PSI pressure washer than you
hardwater or sof````er doesn`t have any effect on foam
i also have try autobrite foam lance vs mjjc foam lance
same dilution, same shampoo, autobrite produce thicker foam..
i hate that brian guy who claim like he know everything about water
i only has try 3 of chemical guys shampoo, honeydew, citrus, and mr pink.
this is my favorite between the 3
they don`t claim this shampoo to use for touchless wash, so i can`t complain, but they do claim it on honeydew shampoo, it doesn`t work at all
I have seen differences in foaming performance based upon water. I recently moved and had soft water and now I have pure well water that is moderately hard and foaming is reduced with soaps - some more than others. There are more than one variable.
Bunky
chemical guys honeydew video
https://www.youtube.com/watch?v=WWiI9K9nuwI
obviously chemical guys will be using sof````er right?
my honeydew video, hardwater
https://www.youtube.com/watch?v=fDVQFYCWv7k
same dilution ratio
both produce the same thick foam..
but i don`t know about well water tho :P
You can add agents to soften water and foaming agents that will foam well in hard water. I see differences. My water pH is around 7.8 which is not bad but has lots of minerals (calcium).
Optimum works well in hard and soft. Adam`s was good. Hyperwash seemed to foam less in hard water.
Bunky
next week i`ll be review hyper wash B)
alfierenadhie
I will note my experiences is with a bucket wash and not a foam cannon or foam gun. Not all hard water is equal so I expect results to vary.
