Zaino ?
04BlackAV
First I'd like to say Hello to everyone,been lurking for sometime.
I'll try to make this short,I've been using Zaino for a couple of years now.I just picked up a new vehicle a couple of weeks ago and it's Black.It's still cold here and I did manage to wash it in Dawn,clay and put 2 coats of Z5 on it till the weather warms up.
Basically I have some minor swirls and a few lite scratches that I wan't to remove by hand before I reapply the Zaino again.I've read so much here to the point I'm a little confused as to what I can use to polish with that won't affect the bonding of the Zaino to the paint.I'd like to use a polish that I can use Zaino on without washing again to remove oils or fillers.I have hard water and spots real easy so I'd like to avoid washing it again before applying Zaino.Perhaps using AIO before Zaino ?
Thanks Rick
You're free to use whatever polish you like, just wash the vehicle before you apply Zaino and you'll be fine. Don't forget to use Z1 or Z2/Z5/ZFX for your first coat though. After than, depending on how much time or effort you are willing to put in a day - you can then choose to only go with straight Z2/Z5 for the next 4-9 coats.
ZFX/Z1 needs to be used every 10 coats.
Paco
Thanks...I was hoping to avoid washing again after polishing.Z2/Z5 will not remove water spots.What I have been doing is using Z6 after washing and before using Z1/ZFX-Z2/Z5 to remove some of the water spots I always end up with.
