T
tsantoro
Guest
How does Zaino Z-PC compare to Menz or Megs polishes in terms of cutting and ease of use?
G35stilez said:Out of 10, I put Z-PC at a 4 out of 10 - right beside Menzerna 106FF and Meguiar's #80. The key differences I see with Z-PC are:
- No oils, no fillers means what you see is what you get
- Topped with Z2/Z5 Pro, the paint looks notably better than if topping Z2/Z5 Pro over 106FF or 80.
- It cuts pretty quick and finishes quick as well which means a shorter working time.
- Mix in 1 oz of Z6 per 7 ounces of Z-PC and you can effectively use it on the rotary for cutting or finishing.
wannafbody said:Why not just mist the pad with Z6-wouldn't that be easier?
tsantoro said:Thanks everyone. I have another question regarding Z-PC. Should I use a cutting pad with Z-PC to remove deeper scratches and imperfections rather than using a polish with more cutting ability and a polishing pad?
