I tried Z for the first time today. I have been using BF/Blitz with great results but wanted to try Z to see what the differences were. I used Z5/Zfx (3 coats) and used Z6 in between. I didn't do a Z2 coat because I want to put down some more coats of Z5.
I used the PC with the gray pad and did 3 coats with 1/2 oz. I mixed the Z5/Zfx in a 60cc syringe and spritzed the pad with Z6 after each panel. This REALLY made a big difference. I got thin even coats by using the Z6. Before applying the Z I clayed and used some FI II to get some minor swirls out..then Dawn washed the truck. I used MF's from Yo Steve to remove the Z..
Mixing the Zfx/Z5 was the only negative...and in reality it was no big deal...The syringe really helps in measuring precise amounts and using every last drop..there is absoultely NO waste when using the syringe.
The shine is VERY reflective..more than the BF but not as deep..which is what I expected..The Z is definitely slicker than BF. The main reason in trying Z was to compare durability with BF. I have Bf on my wife's car now so I will keep a watch on it.
For future QD'ing Im going to stick with OGSO..I will use Z6 only when appling more coats of Z
