Zaino/da polisher ?
ROCKNROLL
I hope Iam not putting this in the wrong category.
Is anyone using a polisher with Z-2 or Z-5 ? I havent heard this mentioned before and just thought I would throw it to the detail wolves....:D
Just did it today! I use my PC, a blue LC pad and about 2/3 of an ounce and get 2 layers. I apply using about speed 4.5.
Many have said over the years that you waste too much product with a PC but I've found with the right application technique it makes it much easier and faster. Again, 2/3 of an ounce and I had some left over. I don't think that's wasting too much product and is about the same amount if I applied it by hand. Even did my wheels.
To me, the application of any sealant, (Or wax for that matter), is not something I use my D/A for.
Tried it and didn't see any benefit.
That's just my feelings and may not be the case with many people.
I haven't used Zaino for a long time, but other than their Z-PC and possibly their Z-AIO, I wouldn't use the polisher with their products either.
Since you specifically asked about Z-2 and Z-5, I personally would apply either product by hand.
To clarify what I meant.......
The sealants you mentiond are "drops only".
That's why I said you'd probably waste too much.
IMHO Listen to people who have used it, so don't listen to me.
I have used it both ways. When I first started using Z2 or Z2 Pro I used the PC with blue pad and some Z6 to spritz the pad. I did think it was faster and easier at the time. But after a few years I decided that applying it thin is the winning combination so I went with hand application to get the thinnest spread of the product possible.
I think both ways are fine but I found that I use less if I apply the product by hand. I also found that it became faster by hand as well considering set up for the PC and clean up of the pad.
Thanks for the reply , Iam getting sort of the response I thought might turn up. Now, are you using a little cut with Z-6 when applying or straight Z-5 ?
Is that with a red pad ?
As is very often the case, the way to make a decision on the best method for you would be to try it.
But Charles, why would I do that ? I have you pro's around here that have been there dun that.....trying to learn sum thin here....:D...and I appreciate the help too !
I use a blue LC pad, a spritz of Z6 before I start and then another spritz of Z6 about halfway through the car. I also don't apply any pressure to the machine while applying. Just the weight of the machine and glide it on the side panels insuring even coverage.
Thanks, now to remove,are you using a real soft micro fiber towel underneath the pad ,or by hand ?.......:inspector:
I have started (within the past year or so) applying LSP's with a PC or Flex. I feel that I can apply a more uniform and thin coat, making residue removal a lot easier. Not to mention speeding up the LSP application.
Are you applying without pressure ,with just the weight of the machine? and with what color pad ?.....:thanks
Sometimes I put some pressure on it. I want to work that sealant in real well.
Green/white/blue/red pads. It all depends on what clean pads I have at the time. :)
