Zaino cure time
Travlinlght
I have read a few posts about Zaino cureing time. Someone posted that they let their coat of Z5 cure over night and found the shine to be greater. Will allowing the Z to sit longer produce a better shine?
I put on 3 coats of Z5/zfx last weekend , allowed about 30 minutes between coats. I then put on another coat the other day of Z5 (no zfx) let it dry about 30 minutes( finger tested it) came off nice, no smears, good shine. Should i wait longer, even though its dry? Will letting it sit give better results?
Thanks guys
I have found that the longer that you let it cure the better, BUT!!!! If you use ZFX this is not the same! With ZFX I only let it cure 15-30 min. The longest I have left Z5 on is 6 days.......
