nobody said:Hi All,
I would like to find out is it necessary to use AIO after Menzerna Final Polish before layering Z-5?
Or Can I use Z-6 to clean off Menzerna FP then lay Z-5?
Thanks all
regards.
nobody
bert31 said:It isn't necessary but it does receive alot of praise on this board for its cleaning ability and the base it lays down for Z-2 or 5.
If you do not use Z-AIO, you will want to do a 50/50 water/ISO wipe down or a wash to remove the polishing oils in Menzerna products.
nobody said:Hi All,
I intend to give a wash down with Car Shampoo . Maybe will try it out .
Thanks All
Nobody
Jesstzn said:Car shampoo alone may leave residues behind that Z2/Z5 might not bond to.
Just a bit off topic .. has anyome compared k-AIO to Z1? Is it the same stuff?
termigator said:You can use ZPC before Z5. It's just the ZPC is a light polish and it might not get rid of all your swirls. Remember, you can always just do the water/alcohol wipedown instead of ZAIO after the Menzerna polishes and that will wipe off the oils from the polishes.
nobody said:You mean either water or alcohol ? If water it will be ok, if alcohol i doubt i will use it cos later I use the wrong type of alcohol .... lol.Actually Menzerna instuction also mention after polish use damp cloth to wipe it down. so i also believe the oil can be remove with water.
