You only have two, nothing else matters!
Changeling
If you were limited to "two wax's" and two (2) only, for a final finish over a synthetic sealer, what would be your choice?
This site contains lots of "buts", alternates, however, different situations, Etc,.
Surface preparation is not a consideration, consider it perfect!
Deviation from the question means you can't, or didn't even read everything!
One simple question, without comments.
You only have two wax's to use, for the rest of your life, answer the question::argue
Changeling
The sealant I use most often is Werkstatt's Acrylic Jett and I am happy enough with the appearance I generally don't top it.
