imported_Aurora40
I washed my car this afternoon as it got up to almost 70 here. I used the Blackfire shampoo again and then the QD as I dried it to remove any water spots. The car looked awesome and very deep. Then, I decided it was time. I got out the Souveran, opened the top, took a sniff of the lid, and made the first swipe across it with my foam pad.
It is easy stuff to apply and smells great. I hardly used any of it at all. I think I use a lot more when using #26, but maybe I put that on too thick. I did drop three pads while doing it when they got grabby. What I've noticed is if you can't see the haze, you can feel it. When you wipe the pad around the first time, it will feel grabby. But when you go over a part you wiped, the pad will just glide. This lets you know it got coated even if you can't really see it. I also felt the Blackfire on parts before the Souveran went over it. It felt pretty slick still (5 weeks later) and it looked awesome. However, it didn't feel quite as slick as the day I applied it. The Souveran felt incredibly slick, and made the slight loss of slickness on the BF more noticeable.
Anyway, as I'm buffing the Souveran off, the car looks unbelievably deep and wet. And I was doing this in the dark with two crappy incandescent bulbs in my garage (I'm working on getting some better lighting up). I am already impressed with the way the Souveran goes on and the look, and I haven't even seen it in the sun yet. I can't wait to see the car tomorrow!! :xyxthumbs
