Woolite Mixture Question
ndtechie05
hey guys when you say a Woolite mix of 6:1 or 10:1 how exactly do you measure that and which is which. Thanks in advance. Also is a spray bottle the best way to apply?
-Brett
ndtechie05 said:
hey guys when you say a Woolite mix of 6:1 or 10:1 how exactly do you measure that and which is which. Thanks in advance. Also is a spray bottle the best way to apply?...
6 or 10 parts water to one part Woolite in a spray bottle.
I have a related Woolite/Water question. Are you guys wiping the surface with another damp MF and water to remove the soap residue that might be left behind???
In my experience 6:1 is a bit strong, but a little more diluted maybe 8 or 10/1 you don't really see residue.
I've even used it to clean/dust certain furniture and I can't detect residue. I always clean my white refrigirator with it :chuckle:
At 6 to 1 it makes a great household cleaner. At 10 to 1 their should be no residue at all. To check it out try it on a mirror, if it streaks very bad it will leave a residue, if it doesent streak it leaves no residue.
