Wolfgang or Blackfire question...
05Sleeper
I am going to be doing a Blue Acura RSX, and the owner wants to buy. and keep, the products when I am done. I was thinking about using either BF, or WG on this bluse to really help it glow! What do you all think would be the best bet?
Thanks.
Personally, I would go with the BF. Its not the easiest, but IMO, provides one of the deapest darkest richest results attainable with a poly.....Durability isnt an issue either.
Well, what about the Menzerna Kit with FP II, FTG, anf FMJ? Do you all think that would be a better set-up? What would the diferrence be? Thanks!
Then again, there is always the Zaino route... :grinno:
Checkout the Chemical guy's lineup. Buy your products in bulk & provide your clients a 4 oz. bottle of your choice of product.
out of BF and WG, i would lean towards BF...a 2 oz. mister is your friend :)
if you toss FMJ into the mix, i would pick FMJ with no hesitation (skip the FTG). i've stopped using BF for FMJ, i find the results a tad better in every respect. but, you can't go wrong with either product IMO.
I think you are right as far as going with the FMJ, but why should I skip the FTG? Wouldn't a glaze do wonders for a darker colored car?
ANd what would be a better prep for the car which is quite oxidized and has some spider webbing (I will be doing this all by hand)
I was considering AIO, or Blackfire Gloss ENhancing Polish... any other suggestoins? thanks
in my experience i didn't notice a significant enough of a difference when using FTG under FMJ to warrant the additional effort :nixweiss
on the other hand i've never tackled oxidation/swirl removal by hand. so i don't know if FTG will help hide the residual marring.
Well, since I am going to have to do this all by hand, I am considering doing the following:
AIO + NXTr, + ???
I am debating if a coat of BF or WG or FMj would do any justice on top of the NXT. I am just not going to be able to polish the whole car by hand to get out all of the swirls. I did, however, notice that some of the swirls appeared to disappear when I used AIO on a test panel...
Please give me advice on if you think my process is going to turn out well, and if it is worth it to top the NXT with BF, WG, or FMJ. Thanks!!!
After a few months of MenZerna's FMJ & HGAS, I believe they Whoop Zaino right in the Z! :dance ...and I use to be a Z-freak.
