Wolfgang ETS Polishing Pad Tested
RAG
I tested the Wolfgang ETS DA 6.5" polishin pads on a vehicle today using a rotary. I know, I know, they were designed for a DA. However, other company's pads that were designed for DA machines have proven to be great with rotaries. In any case, these (white) pads are a bit stiff and inflexible for a true polishing pad. I would describe this pad as having quite a bit of cut for a polishing pad...on par with Meguairs polishing pad. With the rotary the pad was "squirley" and generated more heat than any other pad I've tried (the foam is dense and doestn' allow much air flow). But a little extra heat on a DA is probably a good thing.
Thought I'd share my findings.
