Wolfgang Deep Gloss Liquid Seal and other WOWA's - Application and Maintenance Questions
plouffy
Hello,
I recently decided to enter into the world of WOWAs by purchasing some Wolfgang Deep Gloss Liquid Seal and have a few questions. I am going to apply like this:
Clay
Polish
Klasse AIO
Wolfgang DGLS 1st Coat
Wolfgang DGLS 2nd Coat
Questions:
1) How much curing time after buffing Klasse AIO before the DGLS?
2) How much curing time between coats of DGLS? Is it an option to wait a week, wash, and apply the second coat?
3) Confused on maintenance: should I apply another coat in a month or two after just washing or will another coat only stick on a fresh surface?
Thanks!
Daniel
1. There is no cure time for Klasse AIO. It is more of a chemical cleaner with a hint of Acylic sealant. And the Acylic sealant cures almost instantly.
2. I believe the ideal is 12 hrs. But in my use I think you are safe even after 1hr. I usually only wait an hour. Absolutely you can wait a week or more and apply another coat.
3. That is how is usually work after my first major application. Wait 2 months or so, then wash it good and add another layer. Unlimited protection if you keep it maintained like this.
Thanks! To clarify the maintenance portion: if new coats are added every 2 months, it is never necessary to strip it and use a chemical cleaner again??
Understanding of course that whenever a lot of contaminants build up it should be clayed again.
In my opinion the only reason to strip it or use a chemical cleaner is if it really needs it or you want to start over.
I only strip it down every 6-9 months when want to start fresh or it needs clayed.
