togwt
The Old Grey Whistle Test
Isopropyl alcohol (IPA) - is readily available and like acetone, it dissolves a wide range of non-polar compounds. It is also relatively non-toxic and evaporates quickly. Thus it is used widely as a solvent and as a cleaning fluid
Mineral oil - can be used to clean heavier oil stains by diluting and liquefying the other oils, rendering the oils more accessible to detergents.
Likewise, it can be employed to de-gum, to remove adhesive residue left by adhesive tape. Be cognizant that while it can be used as a solvent cleaner it can leave a residue, which is undesirable for paint cleaning applications.
Denatured alcohol (or Methylated spirits) - is ethanol that has additives to make it more poisonous or unpalatable, and thus, undrinkable. Do not use denatured alcohol as a substitute for Isopropyl alcohol (IPA)
Distilled water
Potable water usually contains a number of microscopic contaminants (turbidity) along with dissolved minerals such as calcium and iron. Distilled water should ideally be nothing but hydrogen and oxygen molecules and virtually all of its impurities are removed through distillation, which involves boiling the water and re-condensing the steam into a clean container (pH 6.0 – 7.5)
Any dissolved solids such as salt, bacteria, calcium or iron remain solid while the pure water converts to a much lighter steam and is drawn out for condensation, leaving most if not all solid contaminants behind. Distilled water is preferred for dilution as it’s a ‘known’ quality, unlike domestic potable water
In larger chemical and biological laboratories, as well as industry, cheaper alternatives such as deionised water are preferred over distilled water.
Wipe down Application Process
Application - fill a fine misting spray bottle with a dilute solution of isopropyl alcohol (IPA) / distilled water Spray the surface you have just polished and allow the solution sit for approximately 15 seconds. If it flashes too quickly (hot surface or environment) use further dilution
Isopropyl alcohol (IPA) and or other solvents will suspend waxes and silicones, and then re-deposit them, this can be avoided by adding 10% d-limonene (P21S Total Auto Wash) to the dilute IPA solution and wiping the surface with a clean, dry micro fibre towel. (TAW will provide surface lubrication to minimise surface marring on less dense (softer) paints)
Agitate the area with a clean panel wipe or a soft 100% cotton micro fibre towel (you may need to repeat this process) change the towel to a fresh quarter after each panel to ensure oil and debris are not re-deposited and observe. This should have removed any wax or oils that may have filled any remaining swirls and show the true post-polish surface condition.
If a diluted IPA solution doesn’t remove the surface oils perhaps a specific paint preparation product, i.e. CarPro Intense Oil & Polish Cleanser or DuPont PrepSol II™ may be more suitable
Now using your surface inspection light, shine the light directly on the panel and look for fine swirls. If they are still present, you should be able to see them. If not you will see a clear bright reflection from the panel with a great shine, and clarity
These fast acting solvent cleaners will not leave a film residue
• CarPro Intense Oil & Polish Cleanser
• DuPont PrepSol II™
• Menzerna Top Inspection
• Wurth Clean Solve
Mineral Spirits (White Spirit) are a petrochemical based product (Stoddard solvent) it also contains oils, so its use in a paint wipedown process is self-defeating as you’ll need to remove the oils from the surface
Notes:
1. For dense (hard) clear coat use a very light dilution rate, for less dense(soft)clear coats use a more diluted solution, as use too much alcohol will cause a micro fibre to offer more surface resistance and may cause surface marring.
2. After the paint surface has been subjected to a chemical cleaning its protective layer (s) have been removed and the paint surface left without protection, so it is very important that a wax or polymer protection be applied immediately.
Alternative products
• 3M™ Prep Solvent-70 (#08983) is a low VOC, water- based solvent used to remove oils, wax, grease, and silicone from surfaces prior to the application of a coating. Effectively cleans metal, primed metal and painted surfaces. Use with 3M™ Panel Wipes (#4567) the Panel Wipes have excellent absorbency and are super strength when wet or dry. They are easy to carry and are supplied in an easy to dispense box.
• CarPro Intense Oil & Polish Cleanser - is anti-static, isopropyl alcohol (IPA) based cleaner designed to dissolve oil particles and remove polish residue to inspect the surface after polishing or to prepare the paintwork for the application of a coating product. Its intense cleaner dissolves oils and it also attracts the dust left by compounding. When you wipe down your vehicle with Eraser, you’re removing oils, fillers, and dust completely. Enabling a coating to form a stronger bond and create an even, long-lasting shine with a more durable protection.
• DuPont PrepSol II™ - http://www.xurex.com/products.html) spray onto a 100% cotton or a micro fibre towel and clean the surface
• Groit’s Paint Prep - to remove wax, silicone polymers and oil from painted surfaces so products can properly bond to the surface. Paint Prep is easy to use and is safe for vinyl and rubber (not for use on glass)
• Hi-Temp's H-23 Prep Wash - to prepare a paint surface for polishing, compounding, wax and / or polymer sealant application (especially if changing from a wax to a polymer product) this is a water-based paint cleaner designed to remove all traces of silicone, oil, and buffing residue from any exterior paint surface
• Menzerna Top Inspection (PP95) – use to inspect your work, use this water-based cleaner that removes dust left by compounding and any lubricating oils so you can see the real results of your work. There are no silicones or fillers, just cleaning agents to uncover the real condition of your vehicle’s paint
• Optimum Power Clean - Optimum Power Clean™ is an environmentally friendly, all surface-safe cleaner, used for paint dilute it 2:1
• Wurth Clean Solve - is a fast acting cleaner and solvent that will not leave a film residue. It will quickly remove wax, tar, gum, grease, paint overspray, adhesive, oil, and silicone. It can be used on a variety of surfaces including: base coat, clear coat, aluminium, fibreglass, glass, fabrics and vinyl.
[Edit: General updates / Revisions - 07.16.12]
Distilled water
• Wurth Clean Solve
Notes:
