Wipe on, wipe off?
luke667
i was wondering, with products like meguiars cleaner wax, meguiars stage 1 polish, meguiars #26, is it advisable to wipe on and straight off, panel after panel, or should i leave it for 10 mins?
Umm... did anyone really answer this? :nixweiss Those products AFAIK are supposed to be left to dry to a haze before buffing off. Sometimes, as is the case with Klasse SG, somebody discovers that it works when buffed off immediately, but in most cases products are recommended by the manufacturer to dry first because they are then easier to buff.
Some products like the ones jgv listed can or should be buffed immediately as they were designed to be.
I agaree, the bottle of SG says to let dry but what does Klasse know they only make the stuff.
Hey with Meguiars Cleaner Wax you should let it dry to a haze before wiping it off. Otherwise it won't do much for you. I believe this is also true with almost a waxes except spray-on ones.
jgv said:
It takes a minute or less to dry.....
Agreed and in my experience, using the wipe on/wipe off method does not affect durability or slickness, even 3 months since initial application.
