Winter Vehicle Preparation / Driving
togwt
The Old Grey Whistle Test
The onset of winter can be bad news for motorists. Little light, bad weather and worse roads conspire to make driving tiring, unpleasant, and sometimes even dangerous. This article will show you how to prepare your vehicle for winter driving and remain safe. Make sure that the car is warmed up, and has enough fuel, let someone know your intended movements and listen to traffic news and weather forecasts, and wear warm clothing.
Snow and Ice Removal Products
1. Intro-Tech Automotive Snow Shades protect your windshield with four frost-stopping layers. Keep your windshield clear and ice-free during the coldest of winter seasons. Outer clear coating, silver aluminium foil film and mesh lining stops snowflakes from collecting. And, a black vinyl inner layer snuggles your glass to keep it from freezing. Plus, these snow shades are custom-made to cover every inch. Easy to store, just roll it up into its convenient carrying case and toss in your trunk or back seat. And, you can enjoy your snow shades for many chilly seasons to come - Intro-Tech backs them with a Lifetime Warranty
2. Ice Remover-strong enough to rip through thick ice, The Ice Master removes ice four ways! The patent pending design features repositionable blades that lock into different positions to suit the job at hand. Clear hard ice, thick ice, frost, and snow with this ingenious windshield ice scraper. Three deburred brass blades effectively remove ice from windows and mirrors without scratching. Hard polycarbonate teeth break thick ice. The Ice Master is made with gloved hands in mind. Each position can be achieved with a simple push or pull motion
3. The Snow Moverâ„¢ is the world's first personal snow plough, designed to remove deep snow from on and around your vehicle. This multi-tool combines a plough, ice scraper and shovel - along with a special snow broom, ergonomically designed to work with the body's natural motion. The result is a powerful, yet surprisingly easy-to-use snow moving experience. The design includes a contoured saw-grip handle, which makes for easy manoeuvring when clearing snow from the roof of the vehicle. The first snow plough with 'whiskers'; these dense rubber bristles, located under the forward lip of the plough, can be used to whisk away any snow debris from the surface of the vehicle, including the window glass. The bristles ride over any protuberances (such as a roof rack) to prevent a jarring stop when ploughing through deep snow and will not damage the paint or surface finish of your vehicle
4. The Ice Master removes ice four ways! The patent pending design features repositionable blades that lock into different positions to suit the job at hand. Clear hard ice, thick ice, frost, and snow with this ingenious windshield ice scraper. Three deburred brass blades effectively remove ice from windows and mirrors without scratching. Hard polycarbonate teeth break thick ice. The Ice Master is made with gloved hands in mind. Each position can be achieved with a simple push or pull motion
5. WeatherTech® Classicâ„¢ Premium - winter car mats, rubber floor mats made out of natural heavy-duty rubber These all-weather mats have deeply sculpted channels designed to trap water, road salt, mud and sand. Made of up to 16 lbs. of pliable natural rubber, these mats won't curl, crack or harden in sub-zero weather.
They also have anti-skid ridges to prevent shifting in your vehicle and come with a protective, non-stick finish to make cleanup quick and easy. They meet FMVSS302 standards; TUV approved and comply with ISO 9001 standards Colours available- black (with red pinstripe), Tan or Grey
Product Storage
Water-based car care products should not be stored at temperatures below > 35.OF (wax 45.OF) if they freeze they may become unstable and therefore unusable, ideal storage temperature range- 50- 7.OF with an average humidity range. Most car care products have a ‘useful life’ of approximately 2-3 years provided they are stored as above.
Keep containers tightly closed in a dry, cool and well-ventilated place. Keep away from direct sunlight. Do not allow to freeze. Do not store at temperature extremes (below 40 – over 80.OF +) as heat will destabilise emulsified products (wax, polymer sealants, polishes, etc) and avoid extreme temperature swings as the chemicals will become unstable, which will create problems with the performance of the product. Some separate out; others lose their effectiveness if they are heated past a certain point. Most car care products (including Polymers) will separate and may become unusable after being subjected to freezing temperatures
Clear the Snow / Ice
Start by clearing the snow from around the driver’s window and mirror so the snow does not fall in when you open the door. Start the engine and then turn on the front and rear glass defrosters, seat cushion heaters and side vents.
Then, start removing the snow, stand on one side of the car. Using a long-handled snow plough (Snow Moverâ„¢ ) push the snow on the roof of the car as far to the other side as you can reach, leave a 1/2-inch of snow to melt by itself as this will avoid surface scratches. Once the roof is mostly clear, continue pushing the snow on the rear window, trunk, windshield and hood. Walk around to the other side of the car and use the snow plough to clear the piled-up snow off the car. Use the snow brush to remove any snow that hasn't come off the windshield, hood or headlights. Use an ice scraper to remove any ice from the windshield and other glass surfaces.
Clear snow from the roof as well as from windows, snow piled up on the roof can fall onto the windscreen obscuring your view and can also be a hazard to other road users (this is also illegal in some states/ countries and subject to on the spot fines).
Winterize your car
While many people take special care to prepare their homes for the winter, they often never consider that their car might also need some special preparations for the cold weather.
When winter approaches there are some basic things you must do to make sure your vehicle remains reliable and safe. Whether you live in an extremely cold location or you plan to travel during the winter, it's important to take proper precautions. You never know, proper winterization of your car might just save your life one day so it is important to take proper precautions before it is too late
Winter Visibility
Windscreen washer fluid should be topped up and treated with a proprietary additive to reduce the chance of freezing in frosty weather.
Don't use ordinary engine antifreeze as it will damage paintwork.
Iz Einszett Anti-frost Washer Fluid will improve your visibility in harsh winter weather by keeping your windshield clear of ice and frost. This concentrate cleans windshields without leaving smears or creating glares, and prevents re-icing. For your safety, use Einszett Anti-frost Washer Fluid to keep your windshield frost-free all winter and also removes road grime, salt, and dirt with clean, glare-free and smear-free results. This product doesn’t use methanol and ammonia.
Use at a stronger dilution in the winter to prevent freezing at sub zero temperatures. Dilute 1:5 for protection down to --20.OF, Dilute 1:1 for protection down to -5.OF, dilute 1:2 for protection down to 11.OF, dilute 1:3 for protection down to 18.OF, in summer dilute at up to 1:20
Wurth Screen Wash Additive is a cleaner and antifreeze for your windshield. Regular use prevents the freezing of your windshield and headlight washer systems. This is vital in cold weather to keep your windshield clear of frost, ice, salt, and oil. Calcium inhibitors prevent deposits that cloud your visibility. Your windshield stays clean and clear no matter what the conditions are outside.
Just mix Wurth Screen Washer Additive with water according to the directions and pour it in your washer fluid tank. Overspray will not affect your paint, lens covers, or rubber gaskets. The citrus-scented additive prevents freezing down to -22. °F when mixed accordingly.
Iz Einszett Eistau De-Icer - quickly de-ices windshield. Special additives prevent re-icing, it will not harm paint, chrome, rubber or glass. Helps to provide clear visibility, prevents filming which causes dangerous glare, also suitable for plastic headlight lenses. Doesn’t contain methanol or silicone
Windscreen washer fluid should be topped up and treated with a proprietary additive to reduce the chance of freezing in frosty weather. Don't use ordinary engine antifreeze as it will damage paintwork.
Window fogging
How many times you entered your car and got immediate fog and hazy windscreen?
Your safety depends on fog-free vision; wiping fog from glass with your hands will not remove it. CarPro Fog Fight is a super hydrophilic coating (less than 20 degree contact angle) so the moisture doesn't bond to the glass, which eliminates tiny water drop condensation, Durable long lasting anti fog or steam treatment.
It is also paramount that the glass is grease free, so a wipe over with eraser prior will certainly help and also make sure there is no moisture present on the window before application. Use the cars heater or air con, if needed to ensure this is the case.
Apply a very light misting to the interior glass surfaces and mirrors, allow it to haze lightly and with a very gentle buffing action slowly go over the treated areas. Use lots of light stroke with no pressure and again with the suede Microfiber towel included in the kit. Too heavy a napped cloth will damage the layer. Once there is no residue left, reapply a second coat in the opposite direction to ensure even coverage. Buff of with many very light strokes but do not scrub.
Once product has been applied avoid touching glass (if you need to clean the glass, re-apply product)
A British company Bilt-Hamber Laboratories has a new product - Dynax UC new high-performance anti-corrosion wax provides a touch-dry firm wax film that's virtually invisible, a low film thickness see-through protective shield. Its firm wax like film is rich in unique metal seeking corrosion inhibitors that stop existing and prevent new corrosion. It can be applied to bare metal or painted surfaces in fact anywhere where a discrete and powerful inhibitor is needed.
Completely safe to use on the vast majority of paint coatings and is ideal where dark colored waxes or under seal would detract from the painted finish of vehicle bodywork or underside. The touch dry, spray-on wax film also provides a tough mechanical protection to protected surfaces.
This is the ideal product to provide high levels of protection from salt corrosion during the winter months
Vehicle Mechanical Preparation
Avoid the doors freezing shut – use a protection product on the ‘rubber’ seals Gummipflege Stift - it applies directly from the bottle like a shoe polish, as it has its own foam applicator or Wurth Gummi-Fit Rubber Seal Conditioner & Protectant
Engine, Fuel and Cooling system care as recommended by National Institute for Automotive Service Excellence (ASE)
• Engine Performance - Get engine driveability problems (hard starts, rough idling, stalling, diminished power, etc.) corrected at a good repair shop. Cold weather makes existing problems worse. Replace dirty filters-air, fuel, PCV, etc.
• Fuel - Put a bottle of fuel de-icer in your tank once a month to help keep moisture from freezing in the fuel line. Note that a gas tank which is kept filled helps keep moisture from forming.
a) Diesel - Like most fuels, diesel is a mix of hydrocarbons, and the components have different freezing points. For Number 2 diesel, as the ambient temperatures drop toward 32 degrees F (0 degrees C), it begins to cloud, due to the paraffin in the fuel solidifying. As the temperatures drop below 32 F, the molecules combine into solids, large enough to be stopped by the filter. This is known as the gel point, and generally occurs about 15 degrees F (-9.5 degrees C) below the cloud point.
This wax then forms a coating on the filter which results in a loss of engine power. The same thing happens on starting an engine when the temperature is below freezing. The filter becomes almost instantly coated with wax - usually, enough fuel gets through to allow the engine to idle, but not attain operating RPM. There are two common ways to overcome this: one is a diesel additive, the other is a fuel heater
Special low temperature diesel contains additives that keep it in a more liquid state at lower temperatures, yet starting a diesel engine in very cold weather may still pose considerable difficulties.
b) Gas (Petrol)
Most states requires that all gasoline sold contains 10% ethanol, which is alcohol. Gas Line Anti-freeze is either Methanol or Isopropyl alcohol. The difference between ethanol and Isopropyl alcohol is ethanol is made from corn and Isopropyl alcohol is made chemically. So a 10% blend of ethanol and gasoline contains not one, but two types of "Dry Gas". Now why pay for something that is already being pumped into your tank?
Oil - the Society of Automotive Engineers (SAE) has established a numerical code system for grading motor oils according to their viscosity characteristics. The first number with the "W" refers to the oil's cold temperature viscosity or cold-start viscosity rating, while the second number refers to the oil's high temperature viscosity
Engines typically require thinner oils such as 5W-30 or 5W-20 to speed lubrication of the overhead cam(s) and valve-train when the engine is first started.
Change oil with suitable winter rating and oil filter as specified in your manual -- more often (every 3,000 miles or so) if your driving is mostly stop-and-go or consists of frequent short trips. In cold weather winter seasons, cars use up more engine oil, so always check the oil level in your car before and after driving
Cooling System - test your coolant with a hydrometer, but corrosion inhibitors tend to give out before the rest of the coolant. A Tigard pre-mix prevents sludge build-up and keeps the waterways corrosion -free. Antifreeze, also known as engine coolant, is a liquid substance which circulates through an internal combustion engine and draws off excessive heat.
The two most common chemicals used as antifreeze are ethylene and propylene glycol, both of which have lower freezing points than water (32. °F or O.OC) this allows antifreeze to flow freely even under cold winter conditions. Antifreeze also has a higher boiling point than pure water, which makes it ideal for summer use as well.
The cooling system should be completely flushed and refilled as recommended. The level, condition, and concentration of the coolant should be checked periodically. (A 1:1 ratio of anti-freeze and water is usually recommended.)
Purchase an antifreeze tester, available at automotive parts stores. It's easy to use, and the instructions are included on the packaging. This will tell you whether you have the correct strength of antifreeze for the conditions you are likely to encounter.
Glass weatherproofing seals - use 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger� provides a temperature-resistant seal and a low-shine matte finish
Windshield Wipers - Use the right windscreen fluid; together with proper wipers, an antifreeze solution will keep your windscreen clean at all times Replace old blades. If your climate is harsh, purchase rubber-clad (winter) blades to fight ice build-up. If your wipers are frozen in place, leave them to defrost or use a de-icer, pulling them off can rip the rubber.
Spare Wheel - check the pressure and condition of your spare tyre periodically, if your vehicle has the spare underneath, check its mounting hardware and spray periodically with AMSOIL Heavy Duty Metal Protector.
Also check the cars jack and wheel nut remover and have a drop cloth and a pair of cloves available. If you have after-market wheels be sure you have suitable wheel nuts available for the spare wheel... No surprises
Rain-X Latitude wipers work any better than my clunky original equipment blades. Well, yes they do. First of all, they don’t freeze up and warp out of shape. We’ve had temperatures down to minus-25 Celsius in Ottawa lately, and the Rain-X wipers have held their shape. They also don’t chatter at speed, although I have heard from some colleagues that similar designs do. These seem fine as they also don’t get packed with snow and ice, and should, therefore, obviate the need for purchasing winter blades.
Anti-fogging - windscreen; Glass Science Fog Clear Gel prevents interior fogging of the windshield, windows, and mirrors. One clear coat creates a moisture absorbent barrier that prevents the formation of condensation. Maintain optimum visibility in humid, rainy, or cold weather conditions, Fog Clear keeps working to maintain optimum visibility. Stock up on windshield washer solvent-you'll be surprised how much you use
Avoid locks etc freezing shut – ensure locks, latches, folding door mirrors, etc are dry by using a heat gun / hair dryer and then apply a water displacement product (WD-40)
• Heater/Defroster - Test heater, rear screen defrosters and hoses the heater and defroster must be in good working condition for passenger comfort and driver visibility. Carry an ice-scraper.
Batteries are probably the biggest single cause for non- starting, especially in colder weather. Batteries are less efficient the colder they get so the start of cold weather usually shows up any inefficiencies with the battery.
One of the checks that can easily be carried out is the voltage output; this can be done with an AC/DC Voltage Tester
With car running put voltage tester over the battery +/- terminals, if alternator is ok you should see a reading between 13.5 and 14.5 volts any less and the alternator may be faulty.Other testing will require the use of specialist professional equipment.
Routine care: Scrape away corrosion from posts and cable connections; clean all surfaces; re-tighten all connections. If battery caps are removable, check fluid level monthly. Removal of cables can cause damage or loss of data/codes on some newer vehicles. Check your manual. Have your battery and its charging system checked (‘jump’ leads may be useful for you, or to help someone else)
The reason for the increased demand for electrical power in a car is explained by the growing number of electrical and electronic safety and convenience systems now being fitted. They help to make passenger cars safer, more economic and more comfortable – however, they increase the consumption in electrical energy. In a modern mid-range car, the power consumption reaches more than 3,500 watts. In the Nineties, the value for a lower to mid-range passenger car amounted to only 950 watts.
CCA - stands for Cold Cranking Amps, this figure is very important on a cold winters morning and refers to the big flow of power needed to turn over your engine.
Ah - stands for Amps per hour. This means that the battery when fully charged delivers a starter current of X amps per hour, which means there are X amps available to start the engine.
Bosch AGM High-Tec is available in two models, which will provide an overall market coverage of 90 percent – based on cars that are already fitted with AGM batteries as original equipment. The battery type S6002/019 BOSCH AGM HIGH TEC Battery is absolutely maintenance-free, 100% leak-proof in any position and extremely vibration-proof. With a 6 Years Guarantee, 70 amp hour capacity and delivers a starter current of 760 amps; the 95 amp.hr battery delivers 850 amps at engine start.
Absorbed Glass Mat (AGM) Batteries
• Safer: much lower production of hydrogen gas during charging
• Maintenance-free: no checking fluid levels or adding water or acid
• Sealed: spill proof and can be mounted in virtually any position
• No corrosion: battery terminals stay clean
• Less internal resistance: provides more CCA than wet batteries
• Heat and vibration resistant: a result of its internal construction
• Slower self-discharge rate: ideal for vehicles that see little use
• Longer service life
• Automatic battery charger - The Yuasa Smart Shot automatic battery chargers are available in 900 milliamp and 1.5 amp charge capacities Automatic 12V 900 milliamp and 1.5 amp charge capacities ;fully automatic 3 level charge cycle for effective charging, reaches 14.4 volt peak, then automatically switches to float, with reverse polarity protection
• Lights - Inspect all lights and bulbs; replace burned out bulbs and carry spares; periodically clean road grime from all lenses. To prevent scratching, never use a dry rag.
• Exhaust System - Your vehicle should be placed on a lift and the exhaust system examined for leaks. The trunk and floor boards should be inspected for small holes. Exhaust fumes can be deadly.
• Tyres (Tires) - Cold weather tyres are designed for driving on cold winter roads and in rain or standing water, whenever the temperature is regularly below 45.oF (7.oC) tyres lose grip. Use the most appropriate tyres for the weather conditions. In practice this means keeping two sets of tyres – 'winter tyres' are made with a different composite from conventional tyres and improve traction when temps are below 7.0F and when many roads are snow-covered and 'summer' tyres for the remainder of the year. Summer tyres should not be used when there's ice or snow on the road. I’m not a great believer in ‘all season tyres’ though
Tyre thread; you need at least 2/32" of depth to be safe. It's been my experience, especially in winter weather, that anything less than 4/32" (1/8") be replaced soon. Also, be sure to check your tire pressure. Believe it or not, they lose a little pressure when it gets cold, so check the tyres pressure regularly
Worn tyres will be of little use in winter weather. Examine tires for remaining tread life, uneven wearing, and cupping; check the sidewalls for cuts and nicks. Let the tyre "cool down" after driving before checking the pressure. Rotate as recommended. Don't forget your spare, and be sure the lifting jack is in good condition.
A cheaper alternative to snow chains, they are fabricated from a textile that optimises grip. Towequipe Multi Grip Snow Ice Sock Chains - > Snow Chains Sock | Towequipe.co.uk
• Brakes - Inspect your brakes; its never a good area to cut corners. Be sure your brakes have enough meat left to get you through the season. If the brakes are not performing well, the car may pull to one side or worse yet, may not stop at all.
On ice, braking distances can be ten times longer than in normal conditions so keep your speed down and leave plenty of space from the car in front. Drive in a high gear, no lower than third to reduce the chances of wheel spin. Use 'cadence braking', which is braking with a pumping action to avoid the wheels locking and the flashing brake lights will also warn drivers behind.
•To control a skid, don't press the brake pedal or the accelerator. For a slight slide, turn the steering in the direction of the skid and ease off the accelerator until tyre grip is regained. If the skid is more violent, take your feet right off the pedals and steer sharply in the direction of the skid. If the rear of the car swings left, steer to the left to bring the front and rear wheels into line.
• WeatherTech™ rubber floor mats or Husky Liners WeatherBeater™ are available for most popular vehicles
Warm clothing – the car’s interior may be as warm as toast but if you have to step outside, you could be in trouble if you have not got any warm clothing with you.
Always pack the following: warm coat, hat, gloves, sturdy boots, a space blanket to keep you warm if you get stuck. Take some food, protein bars, water and a hot drink if you can. Always carry a fully charged mobile, and some old bits of carpet, or cat litter, to put under the tyres when stuck and a shovel to clear snow.
Notes:
1. Take along emergency supplies; ice scraper, gloves, sand and snow shovel in trunk, foil blanket, its construction maintains body heat in emergency situations plus a good flashlight, battery jump leads are also indispensable.
2. If you are storing your vehicle for the winter see article “Vehicle Long-Term Storage�
3. Winter detailing - the vehicle’s paint system, tyres, glass, plastic and other exterior surfaces will be at the mercy of the elements, including wind, rain, sleet, snow, sand, gravel, and road salt. Autumn is your best opportunity to inspect and prepare your car for the ravages of winter.
4.By providing the exterior paint system with a polymer or acrylic protective layer to provide a durable protection your car's paint, tires, leather and rubber trim all need attention, even if you have cared for them all summer.
Driving in snow and ice
Here is some advice on how to prepare your car for winter driving if you have to make a journey. This is what the Institute of Advanced Motorists recommends.
• When driving in snow, get your speed right - not too fast so that you risk losing control, but not so slow that you risk losing momentum when you need it - and brake, steer and accelerate as smoothly as possible.
• Start gently from stationary, avoiding high revs. If you get yourself into a skid the main thing to remember is to take your foot off the pedals and steer.
• Only use the brake if you cannot steer out of trouble.
• Double or even triple your normal stopping distance from the vehicle in front. Drive so that you do not rely on your brakes to be able to stop - on an icy surface they simply may not do that for you
Washing your vehicle in winter
• Touchless car washes use very high alkaline soaps to do the cleaning, one or two washes and your paint protection (wax or sealant) is gone. After a couple of this type of wash will cause a hazing due to the harsh chemicals used.
• Hand wash places work on volume not quality so they do they dry with paint safe towels. They will inadvertently leave swirls or worse on your paint surface
• Weekly go to the wand wash and use just the first rinse water and get off all the heavy salt /road grit and d spray the undercarriage Use the second rinse cycle and allow the paint to air-dry.
• If you have out a pre-winter detail and have a good sealant and a sacrificial wax on your car the salt and chemicals can be removed along with the renewable wax; remember to re-apply the sacrificial wax and your paint should be well protected.
• When clearing snow from the vehicles paintwork leave an inch of snow to melt on its own, otherwise you risk moving snow and grit across the paint that will cause scratches, much like using sandpaper.
Optimum No Rinse™ Wash & Shine (ONR) is an innovative product that protects automotive paint, while preserving our most valuable resource, water; enabling you to wash your car anywhere, anytime even inside your garage. It’s a multi-purpose product that serves as a shampoo additive, no rinse wash, quick detailer and clay lubricant.
Use as a winter car wash or in areas that have hosepipe ban, water usage restrictions, or where a water supply is not readily available (apartments, car shows, etc; cleans and protects while minimising water usage, 100% environmentally safe and it reduces water usage to a fraction of a conventional car wash, 1- oz ONR per 2- gallons of water to wash the entire car.
When sprayed on a dirty surface; surfactants break down the soil by releasing its surface tension or bond with the surface, encapsulating the soil particles, and the polymers provide surface lubrication to enable safe (marring free) removal
To remove salt and road grit or to clean really soiled surfaces I would suggest a pre-rinse to remove the larger dirt particles first before being washed. Then use the ONR concentrates or the traditional two-bucket wash method or if you have a pressure washer available to remove the larger dirt / salt particles. (For further information see the technical article “Rinseless Car Wash�)
Optimum Optiâ„¢ - Clean is a product that is specially formulated to clean and protect automotive surfaces safely and efficiently without using water. A combination of polymers and surfactant cleaners safely removes dirt and grime and leaves a glossy protective finish. Based on the same surfactant type polymers used in Optimum (OPT) No Rinse Washâ„¢ & Shine New Formula (ONR) it is safe for use on all automotive surfaces.
ONR works fine for a car with light to medium road dirt while Optimum Optiâ„¢ - Clean can be used on a car with several days of built- up road dirt and grime.
The reason is that Opti™ - Clean contains the same polymers as ONR that encapsulate dirt but at a much higher concentration, as well as additional polymers not used in ONR. A totally waterless wash that provides some surface protection and its ideal for a quick clean up or for use when there is no water available (apartments, condominiums, concours d’élégance or car shows)
[While both of these products are pH neutral, Optiâ„¢ - Clean contains much higher levels of polymers than No Rinse as well as some new polymers that we developed for this type of application. The added polymers are necessary to compensate for using a fraction of the water as compared to a regular No Rinse wash] David Ghodoussi OPT.
Application- avoid cross-contamination by using different micro fibre towels for differing surfaces i.e. separate towels for glass, paintwork, wheels, and interior surfaces. Spray liberally on painted surfaces and wipe clean with a plush microfiber towel.
Fold and use a new section of the towel as needed. For glass and interior surfaces, apply one or two sprays and wipe off with a clean plush microfiber towel. For lower panels and wheels, spray liberally and let it soak for a few seconds and then wipe off. When there is heavy dirt build up, use Optimum (OPT) No Rinse Washâ„¢ & Shine New Formula (ONR).
Directions for using the concentrate:
• Dilute Optimum Opti™ - Clean concentrate 1:3 with distilled water.
• Spray liberally on painted surfaces and wipe clean with a plush microfiber towel. Fold and use a new section of the towel as needed.
• Glass and interior surfaces, using a separate micro fibre towel apply one or two sprays and wipe off with a clean plush microfiber towel.
Wheels and lower paint panels, using a separate micro fibre towel, spray liberally and let it soak for a few seconds and then wipe off. When there is heavy dirt build up, use Optimum (OPT) No Rinse Washâ„¢ & Shine New Formula (ONR).
Paint Protection / Detailing
• Apply a paint protection sealant (G|techniq C1 Crystal Lacquer, Zaino or Duragloss #105 Total Performance Polish) and then an sacrificial LSP for extreme conditions (Collinite's Super Doublecoat Auto Wax (476s) and / or Insulation Wax (845) or Finish Kare FK1000P)- use a damp applicator, work the wax into the surface to ensure a very thin layer, allow to dry for approx one hour (do a swipe-test) remove the residue with a clean micro fibre towel, its durable enough to resist salt, grit and repeated detergent washings, protection will last approximately 4-6 months
• Apply Leather Master’s water-based (hydration) protection to the leather upholstery
• Clean and vacuum the carpets Install all-weather floor mats; Weathertech ™ Premium all-weather floor mats, made from natural heavy-duty rubber., Deeply sculpted channels that trap Water, Road Salt, Mud, and Sand, designed with anti-skid ridges to prevent shifting, won't curl, crack, or harden in sub-zero weather, with non stick finish for quick and easy cleanup, TUV Approved, manufactured to ISO 9000 Standards, 10-Year Warranty
• Clean, treat, and dress your tyres and apply a wheel surface sealant coating G|techniq C5 Wheel Armour
• (Dry) Salt is inert but it is also hydroscopic, so be aware that once you add water (meting the snow / ice ) to salt it becomes alkaline pH 9.0 (corrosive) take care to dry the affected area thoroughly after the salt has been removed and neutralize it with an mild acid
• After removing road salt, dirt, road grime, and etc with a pressure washer (Karcher Model K5.93M) neutralise the effects of the alkaline sprayed brine solution on the suspension, wheel wells and the undercarriage. Use an alkaline (pH 9+) car wash concentrate or ValuGuard Acid Neutralizer diluted 1:8 wash with solution, or spray Eastwoods Road Salt Neutralizer to deep-cleans painted surfaces to remove alkaline deposits (like salt brine solutions) Rinse thoroughly and then dry paint surface
• Spray the inner wheel wells with Chemical Guys ‘Bare Bones’ spray it on sub frame, springs, wheel wells, fender wells, etc. and it provides valuable protection from road dirt, road salt, etc.
Alternative product - Innovative Chemicals Inc. SaltX - http://www.salt-x.com/salt-x3.htm
Storage (Products)
Water-based car care products should not be stored at temperatures below 35 - 40oF, if they freeze they may become unstable and therefore unusable, ideal storage temperature range- 50- 75oF with an average humidity range. Most car care products have a ‘useful life’ of approximately 2-3 years provided they are stored as above.
Do not store at temperature extremes (below 40 – over 80.0F +) as heat will destabilise emulsified products (wax, polymer sealants, polishes, etc) and avoid extreme temperature swings as the chemicals will become unstable, which will create problems with the performance of the product. Some separate out; others lose their effectiveness if they are heated past a certain point. Most car care products (including Polymers) will separate and may become unusable after being subjected to freezing temperatures
The chemical composition of waxes rarely ever change regardless of what form it is in, whether it is melted to a semi-liquid or remains as a semi-solid. Temperature has little to no effect as far as inhibiting the shelf life of wax, a cool temperatures and constant humidity will slow the evaporation of solvents from the wax, thus keeping the wax softer and easier to use over a longer period of time.
Removing (Carpets / Mats) Road Salt Stains
Use a stiff brush to dislodge any loose road salt and then vacuum, spray the area with a carpet cleaner and let it soak in, rinse with plenty of water and repeat until most of the stain has been lifted.
Finally clean carpets by spraying the area with a carpet shampoo rinse and then remove with a carpet extractor. Actually, any mildly acidic product should neutralize alkaline salt
Removing Road Salt from Paintwork
ValuGard Decontamination System (B) alkaline neutralizer (pH 1.0) that is a blend of acids, which deep cleans painted surfaces to remove alkaline road salt / water solution deposits (pH 9.0) and safely dissolves salt particles bond with the paint so that they can be rinsed away. Apply to a clean and freshly rinsed surface. Allow product to dwell for 5-7 minutes, works well with detailer’s clay to remove contaminants. All necessary safety precautions should be taken whilst using this product. Protect paint surface with a synthetic polymer sealant Collinite's Insulation Wax (845) or Finish Kare FK1000P
Undercarriage
Your vehicle’s undercarriage; it’s what you don't see that silently awaits underneath your cars. Removing an alkaline sprayed brine solution to protect your undercarriage is just as important as detailing the paint. Wheel wells, sub-frame, springs, fender well and all of the other black and gray parts underneath the body need cleaning and protection as well. It is possible to do this detail with the wheels on and just jacking the car up, but the ideal way is with the wheels off.
Never go underneath a car supported by the supplied jack - always use axle stands if you wish to work underneath the car. Always jack the car up at the manufacturer's recommended jacking points. Ensure the jack is in stable contact with both the jacking point (see owner's manual) and the ground. Always work on level ground.
After removing road salt, dirt, road grime, and etc with a pressure washer (Karcher Model K5.93M) neutralise the effects of the alkaline sprayed brine solution on the suspension, wheel wells and the undercarriage, and then spray Eastwoods Road Salt Neutralizer
Methodology
1. Thoroughly spray an undiluted citrus cleaner (P2IS Total Auto Wash) and let it soak in; remove by thoroughly rinsing with water. If you have a pressure washer available, fill tank with citrus cleaner and spray undercarriage (do not use excess pressure as water may penetrate crevices and seams where it cannot drain, causing corrosion), let it soak and then remove with plain water. Allow to thoroughly dry and then...
2. Spray undercarriage with ValuGard Decontamination System (B) Alkaline Neutralizer pH 1.0 that is a blend of acids, which deep cleans painted surfaces to remove alkaline deposits and safely dissolves the alkaline salt particles bond with the paint so that they can be rinsed away. Apply to a clean and freshly rinsed surface. Allow product to dwell for 5-7 minutes. All necessary safety precautions should be taken whilst using this product
3. Rinse vehicle thoroughly and then apply Chemical Guys Bare Bones, spray over the entire area and wipe in well with an old towel, .one application will leave no residues, noxious fumes or flammable solvents. Makes plastic and rubber look new again, shines painted surfaces, and keeps aluminium and anodized parts from corroding.
4. Protection; apply POR-15 Marine Cleanâ„¢ and then two coats of a rust inhibitor paint (POR-15) allow each coat to dry
As much as we all hate to think about winter and for some of us this means less detailing time and some will store their 'fair weather' vehicle and start using the winter runaround.
I hope the information provided is useful
Good, very comprehensive post TOGWT :xyxthumbs
TOGWT said:
• Tyres (Tires) - Cold weather tyres are designed for driving on cold winter roads and in rain or standing water, whenever the temperature is regularly below 45.oF (7.oC) tyres lose grip. Use the most appropriate tyres for the weather conditions. In practice this means keeping two sets of tyres – 'winter tyres' are made with a different composite from conventional tyres and improve traction when temps are below 7.0F and when many roads are snow-covered and 'summer' tyres for the remainder of the year....
I'm just repeating the above for added emphasis.
AWD/4WD does not subsitute for winter tires (says the guy with three Quattros and a 4WD truck).
It's not about "getting stuck".
Thanks for the comprehensive info once again. The AGM is an interesting topic... the original battery in my miata (a Panasonic AGM was the stock battery in 1999 stock) went almost ten years and was still viable when I just got too nervous to continue relying on it. I figured that AAA probably didn't have them on their trucks and didn't want to sit by the side of the road. Amazing batteries.
Jeff
This shows that there are a number of ways and products to protect your vehicle's finish during the winter season.
Thanks again for the info! I need to go stock up...
:werd: AWD/4WD is only as useful as a driver who knows how to take advantage of it properly.
TOGWT said:
A British company Bilt-Hamber Laboratories has a new product - Dynax UC new high-performance anti-corrosion waxmechanical protection to protected surfaces...
Huh, never heard of that one, sounds good. Thanks for mentioning it.
Protecting undercar aluminum bits is a challenge, and even very limited salt exposure can render them "never quite the same as new" no matter how well you try to bring them back.
Yeah, Quattro is a pleasure in dry conditions in terms of handling, but if you folks are going to be driving in bad snow and blizzards, anything is going to need the appropriate tires.
If I can just recall whose barn I parked the Jeep in, would go get it now and make sure it starts.
Who knows, if I feel the need, might even check to see if it has any oil in the crankcase.
Grumpy
Bill D said:
Yeah, Quattro is a pleasure in dry conditions in terms of handling...
Ya know, to be honest I prefer RWD in the dry, though a more modern AWD system than I have, with more rear-bias, would probably be great.
Just another take-off of Benigan's, which is a wax based rust inhibitor.(been around since the 30's)
Up-dated formula is the ValuGard Rust Inhibitor.
For windshield, one is better off to use AquaPel, but for metal the rust inhibitor.
Grumpy
Mine's an '03 ( although it's an A4) and yours are a '01 and '93, correct? I guess ours are fairly similar and so the most modern RWD are even more a blast to drive huh?
Ron Ketcham- Ah, I was thinking it'd be something more transparent. If the AI/VG Rust Inhibitor is the same stuff I have it's not the kind of stuff I'm after *for that particular application* (love it for other vehicles though).
Bill D.- Roger that on my Audi model-years.
My '93 V8Q has the old (original? I think so...) Quattro system that's simply *incredible* in bad conditions (very, uhm..."mechanical"), but not quite as nice as the same Quattro setup in my VW Quantum Synchro with its various diff lock settings, now *that* was the [stuff] for winter driving! But none of my Quattros are all that "balanced" the way a good RWD car is. But hey, all my cars are mighty old-tech, and AWD systems have come an awfully long way since then; the recent ones I've driven seemed great, though I sure wasn't beating on them the way I would on my own cars.
On the subject of snowtires and 4WD, I've done some interesting comparisons with vehicles that can be shifted from RWD to 4WD, comparing both modes with all-season and winter tires. I'd much rather have RWD with snows than 4WD with all-seasons. And I'll never understand how people think AWD is so great in the winter without snowtires, I mean...gee, been-there-driven-that and it seems like a no-brainer to me :nixweiss
I am not even sure what year it is! Think it may be a early 90's, not even sure where the title is.
Took it in payment for something a couple of years ago, it's Wrangler, soft top, rusted, rusted, rusted but runs good.
Last Feb when we had the 15 inches of snow in 4 or 5 hours, Houston and I fired it up and went bar hopping.
Coming home, up Main Street, even the plows were struggling, we made it through, but the snow kept blowing up on the belts and the lights would dim down for a second or so.
Darned old thing goes through about anything.
Grumpy
I was once told by a mechanic, I think it's with Wranglers, that the radiator drain cock is a royal PITA to get at. I think he said he had to reach through the grille with super long needle nose pliers to grip it.
Ditto on that! Reminds me of the time my wife and I picked up our new Audi S4 Quattro at a dealer out of town in Chicago. We arrived to drive the car home just as a snow storm hit. (Figures.) Not a block from the dealership we headed out and unceremoniously slid right through the first intersection. Luckily nobody was near us. Talk about nearly s***ting in my pants! Seems the fresh summer Michelins didn't like the snow! LOL! Have had dedicated winter tires ever since.
