John Styrnol said:Yes, you can wax too much. After 3-4 layer's it's time to polish/glaze it off, and start over, but this is just me.
David Fermani said:I'd definately not want to use ANY kind of product with abbrasives either. I'd let it wear off before trying to remove it.
02ZTSfocus said:Why not??
Other than a chemical cleaner (IPA, AIO, etc...)I don't think there is any other way that is near as effective. IMO just letting it wear off wont give you a 100% bare paint surface, if your strictly using carnauba products than its not an issue, but for sealants it is a BIG deal.
PhaRO said:If for instance you washed your car and waxed it with say p21s each week. I suspect after a certain point (several coats) the wax isn't going to build any more that you'd be just maintaining a level. Curious to know if I am wrong.
David Fermani said:Explain why an abbrasive polish is necessary for removing wax. Why would anyone want to do all that work(possibly damaging to the finish) instead of wiping their vehicle down with wax and grease remover or IPA? Wouldn't the path of least resistance be the best and in the case of removing wax the easiest/quickest? I've used several paint sealants and I've never had to use it on bear paint. It didn't require it. Maybe with the Zaino's way of thinking, but not with "most paint sealants". After polishing with a wax contained product, I've paint sealed it many times with great results. I just think that most paint sealant's performance is not too reliant on a wax free finish. Am I wrong? Or are the manufacturers for not labeling/explaining their product properly? :soscared:
