Will this work?
Yikes--you are starting out with the big boy. Do some searches on here for "rotary." You will want to probably toss everything that came with the rotary, but assuming the speed is fairly accurate, that is a good deal for that kind of machinery.
Search options:
"rotary pad"
"rotary pad choice"
"cma rotary pad"
Somebody in "the know" help out. Nobody likes to see the "after" pictures of poor rotary usage.
1) Welcome to Autopia! :welcome
2) BE CAREFUL. The speed range on that machine is appropriate enough, but it's going to take a lot of practice to learn how to use that safely, let alone effectively.
As said, do a search, such as a Titles Only search for "rotary" and you should dig up a ton of excellent information on this. Good luck. :xyxthumbs
1) Go here and watch the How-To videos Better Car Care
2) AVOID the wool pads
3) Keep the RPMs down until you are more familiar with the machine
4) Keep the abrasive levels of the products you use to a minimum in the beginning
