breakneckvtec said:
Ok, think I may have the plan set:
wash with dawn
clay
wash
3M SMR, can I use this first? Do I need a paint cleaner first?
P21S paint cleansing lotion, can I put klasse over this or do I need to wash it off first?
AIO
SG, possibly layer with platinum UPP
Ah, the dawn Enigma surfaces again
Dish soap is for the kitchen... Leave it at that. It shouldn't have a place in your detailing arsenal. At the end of the day, Dawn really does little to stripping wax. You need to apply a couple of coats to do so. Actually, there are much harser dishsoaps that probably due a better job (Ivory for e.g.) As for Dawn touching Zaino. NO WAY. Someone along the line got their information mixed up. Dawn is recommended by Sal to be used before Zaino application to removal grime not Zaino. If Zaino was removed that simply, the durability would be in the crapper. You might the crap off the zaino layer (dirt, oil, sap etc) which is good for new product application but it won't remove any of it. To remove Zaino, SMR is probably your best bet without getting into the Alcohol groups.
Wash, Clay, SMR. I wouldn't wash between the clay and SMR. If you want to be really obsessive, go ahead and quick detail (quickly).
If that doesn't cut the mustard. Move up a notch on the polish.
If you're going with AIO - No cleansing lotion needed. Anyway, AIO will remove any PPCL so no worries there.
Washing after SMR/Polish and before AIO/SG???
I would, only because I would want to ensure that the scratches were removed and not hidden by oils/fillers. A 50/50 wipe of IPA/H20 does the trick nicely.
All SMR that I am aware of have fillers in them. If you work the product long enough, perhaps those are broken down. Also, if you application method (Rotary, PC, Hand) may result in many of those breaking down and hence why some people with the 50/50 wipe see a difference and others don't. I'd side on side of caution and do the wipe anyway.
So: Wash, Clay, SMR, Wipe/Wash, AIO, SG, Quick Detail, Admire the shine.
Paco
