will the alcohol in the washer fluid remove wax?
jjagain
winter washer fluid has alcohol in it to keep it from freezing. Will overspray from the washer nozzles remove any wax/sealant from the paint if it gets on it?
It will probably remove a carnauba wax very quickly, a sealant would last longer, how much longer i don't know. :nixweiss
yeah, a little bit but not much you can do about it (or want to do about it). Gotta keep the windshield clean. The alcohol residue evaporates quickly so you should be OK.
