Will RMG remove VM??
-Lebowski-
I want to try a new wet combo and I was thinking VM, RMG seal with IW845. Will the RMG remove the VM? I dont want to waste time with it if its going to remove it.
TYIA
well i really dont see the point in doin both...VM has a light cleaning properties, swirl removing capabilities while the RMG is a pure glaze so it wont remove it but i would just chose one or the other
I have a suggestion-mix the two together and make a pink moose and use them together on the same step-it will help cut down your time.
TYIA
FWIW, I just tried RMG and topped with IW845, and wow!!!!! I will also try RMG with OCW soon.
Here is a shot on my steel grey hood. I only did the hood, short on time.
Steve
I get my RMG from Specialty Motoring Products (Scott).
I'm never used VM, but from my understanding, RMG is more of a pure glaze, whereas, VM has some slight polishing properties.
I've used RMG on a lot of colors, I really love it on reds and other bright solid colors. It also helps reflective properties on silver as well. Really easy to apply too.
