I recently tried this product called Langka blob remover. Basically it encourages you to fill paint chips with touch-up paint. It tells you to layer the paint until it is higher than the OEM paint and then use this Langka stuff to bring the paint layer down to the OEM level.
First of all, I couldn't get it perfect Everytime i used the Langka to remove the blob, I created a dip in the paint surface which was visible (to my eyes, at least). This is a common problem when sanding (or chemical-mechanically polishing): the softer stuff gets polished away first and pits form where the softer stuff is. In this case the softer stuff is the touch-up paint.
I ended up giving up and going to the old-fashioned method of wetsanding the touchup and following up with polishing steps. It looks much better than the Langka solution. Additionally, Langka is full of SOME kind of solvent that smells exactly like paint thinner --- highly volatile and nauseating.
Was it a lack of skill, or a product limitation that made me arrive at my conclusion?
