There is another counter balance weight for 6" pads. To be honest I have it and don't use it. I have a 5" backing plate and use up to 6.5" pads with no problem. I leave the standard weight on when I switch to a 3.5" plate with no problem either. I would only worry if you feel you have excessive vibration. That is the advice given to me by CMA; they have plenty of experience with the pads they sell. I've had no problems.
Porter Cable makes this optional counter weight available for their Porter Cable 7424 polisher if you upgrade from their 5 inch backing plate/pad to a 6 inch, Hook-and-Loop Backing Plate. We have never had any problems or failures using our Flexible 6 inch Backing Plate with our 6-1/2 inch foam pads with the stock weight for normal detailing. If you detail for a living where the machine is in constant use, we recommend switching to this counter weight.
