Below is a link to the original thread where the member had pictures of the paint and the WD-40 took it all off:I *just now* remembered something. My wife's aunts were up visiting her mother a couple of months back and she said one of their newer cars got road paint all over it (they didn't know where it came from either). I thought this was a prelude to me going over and fixing it, but she said they bought some WD-40 and it took it all off..... it's worth a try..... the sooner you get it off the easier it will be.
Mommy Wagon said:I!!!!! After 28 days the difficulty in removal will be greatly increased.
First try WD-40, or Goo-Gone, if these products do not work, you may be required to use a single edge razor, and "shave" away layers slowly, being carful as to not touch the vehicle paint finish. When you can no longer shave the traffic paint away safely, WD-40 shoul now clear the rest away.
David Fermani said:Actually, if you wax the area that has overspray on it, a metal razor blade will glide and not knick the paint. Just a little trick.
Danase carries some:HenrikP said:where would you recommend getting plastic razor blades?
