About 3 months after I took delivery on my car, I noticed that there were hard water marks all over the horizontally flat surfaces of the vehicle. I've never done anything but hand wash/dry it... so I can only imagine they were there since the day I picked it up or acid rain has stained it. With the help of this forum I recently decided to pick up a PC7336 and a pad kit from CMA. A post a while back had reported good luck using 3MFCRC with water marks... so I used it with the PC on a small area to try it out. No luck. A local detalier then suggested I try #2, #9 and finish with #26. The end result was a mirror-like smooth hood... but still no luck on the stains. I also tried #1 with the PC, but since it couldn't generate enough heat to break it down properly, I ended up having a heck of a time fully removing the product... and the end result was no difference anyway.
I guess my question is: is rotary the only way I am going to get these out? They are only really visible in direct sunlight at a certain angle... or at night under the reflection of a streetlamp or other lightsource. But I see them every time I detail the car, and it bothers me to no end knowing I cannot remove them. I picked up some #83DACP which I read was probably the most abrasive product I can effectively use with the PC... and I plan on trying it this weekend. But if this doesn't work, I guess I just need some confirmation that a professional detailer is the only option left.
thanks!
Kevin
thanks!
Kevin
