White EL almost done
imported_doug
In another thread, Guess My Name asked:
"Carguy could you write a post on how to take good pictures."
I edited this post 11-12-02. Half of the images were hosted at a site that doesn't exist any more - so I put them somewhere else. Truth is I am not at all sure I used the same examples for some of these as I had in the original.
It is all about light, focus, distance distortion, and composition.
1) Light is all important. As a rule, bright sunlight is almost always bad. There are exceptions, but cameras (digital or film) can't cope with big differences in brightness nearly as well as the human eye. Overcast days are excellent - especially for photographing people. Light cars show well then too. Even fog can be very dramatic:
The darker the car, the more reflections you get. On a black car, the photo is ALL ABOUT the reflections.
The following example shows this taken to an extreme, by shooting the black car at night:
Learn to "see" the reflections and overall shapes - not the car itself. Natural reflected light will be most dramatic in the "golden hours" which are the hour before sunrise and the hour after sunset.
2) Focus carefully, and understand "depth of field". The surface of the car may be 1 foot from your lens, while the reflection may be 10 feet behind it. The focal length for a sharply focused reflection will be 11 feet. If you really want to focus on the car itself (to show swirls, orange peel or a logo for example) focus the camera at 1 foot. (Most cameras have manual focus capability.) If you want everything sharp, you have to compromise. Focus the camera at about 3 feet, and use the manual exposure mode to set the "aperture" to as small an opening as possible. Lens openings get smaller as the "f" number goes up - so f22 gets you the smallest opening and hence the greatest "depth of field." By contrast, f2 is a very "wide" opening wilh little depth of field. Good to know if you intentionally want to blur the background, as in a portrait. Note that the proper exposure is a combination of lens opening and shutter speed. The smaller the opening, the longer the shutter has to be open. So - for a shot at f22, you better have a REAL steady hand, or use a tripod.
This picture was shot at F2.8 - notice the blurred background:
this picture was shot at F11 - to get the logo and background sharper. If this camera had an F22 setting I would have used it.
3) Distance Distortion is a term I just made up to describe the following phenomenon. Wide angle lenses tend to make the closest object the only center of attention, and everything else gets real small, real fast as its distance from the lens increases. You can get a dramatic effect by getting very close to an object with a wide angle lens. Note that convex curves on your car do the same thing. In this photo, I wasn't all that close but the compund curve of the car made the fence look like it went for a long way - when in fact it only went about 8 feet.:
This image, by contrast, works only because was shot with a long telephoto, which makes the distant cars recognizable. Had it been shot with a wide angle lens, everything past the 2nd or 3rd car would be ridiculously tiny and look even further away. What is harder to tell from this shot is that I had to stand a LONG way from the lead car (mine) - probably 200 feet.
Here's another example of a picture that just wouldn't have worked unless shot with a very long lens, photographer a good distance from the 1st car. Makes all the cars almost the same size:
4) Composition
One of the simplest guidelines I ever learned had the most impact on my photos - so I'll pass it along here. In your mind, divide the viewfinder into 1/3's horizontally and vertically. You should be visualizing a tic-tac-toe board superimposed on the image in the viewfinder. Now - if there is a strong vertical or horizontal line (and in particular, a horizon), place it on one of these lines. Do NOT place it in the middle! If there is a particular item of interest - say, a single flower, place it at one of the intersections of these lines - again, NOT in the middle. Follow this one rule and I promise better pictures instantly. The only bad thing is that auto photography doesn't lend itself to this rule too often. Too bad. But now you know!
With cars, I have a few simple rules. 1. FILL THE FRAME. Most people shoot from to far away. 2. Vary the shooting angle vertically, not just horizontally. Many amateurs photograph everything from eye level. Boring. 3. When in doubt, get closer. Examples:
From above:
From the ground (note the ground in the foreground)
Close!
Finally, <strong class='bbc'>avoid distractions[/b]. The human brain is very good at ignoring stuff within the field of view that it isn't "looking at". However everything in a photo seems to be treated more evenly. I have screwed more pictures by failing to see a piece of trash, a weed, a sign, a light pole sticking up apparently right out of the sunroof. Learn to look for these.
That's about the best I can do. Go out and shoot a lot. Remember, when you see a bunch of photos from a photographer you like, you're looking at the ones he was pleased enough with to show you, not the possibly hundred he threw out! And finally, one last hint: There are exceptions to every rule. These are guidelines. They work - but they are not law.
You can find more of my pics here and on my website.
<em class='bbc'>Originally posted by carguy [/i]
<strong class='bbc'>4) Composition
One of the simplest guidelines I ever learned had the most impact on my photos - so I'll pass it along here. In your mind, divide the viewfinder into 1/3's horizontally and vertically. You should be visualizing a tic-tac-toe board superimposed on the image in the viewfinder. Now - if there is a strong vertical or horizontal line (and in particular, a horizon), place it on one of these lines. Do NOT place it in the middle! If there is a particular item of interest - say, a single flower, place it at one of the intersections of these lines - again, NOT in the middle. Follow this one rule and I promise better pictures instantly. The only bad thing is that auto photography doesn't lend itself to this rule too often. Too bad. But now you know!amateurs photograph everything from eye level. Boring. 3. When in doubt, get closer.[/b]</blockquote>
Awesome Guide.
Can you explain the dividing the viewfinder thing again? I'm not sure I understand it?
Great guide...
At last I actually understand why my Fuji 4900 has the facility to super-impose gridlines on the viewfinder. maybe now I won't end up sending 75% of my photos to the recycle bin when I get them home.
Thanks Carguy:up
That is an awesome post man! One for the archives for sure. I wish we could do stickys in here and always keep it at the top! I can't believe how great those pictures are and what great instructions you give. Bravo!
Thanks, Jngrbrdman
I moderate a forum on another site that uses the same software as this - administrators CAN stick threads. I don't know if it is warranted in this case, but just so you know....
<em class='bbc'>Originally posted by Intel486 [/i]
Awesome Guide.
Can you explain the dividing the viewfinder thing again? I'm not sure I understand it? [/b]</blockquote>Intel486,
Here are a couple of links that describe in a little more detail the "rule of thirds" that carguy mentions:
http://www.studyworksonline.com/cda/content/worksheet/0,1036,EXP16_NAV2-6_SWK35,00.html
http://www.silverlight.co.uk/tutorials/compose_expose/thirds.html
BTW, incredible pics, carguy, and excellent tips . . . :up
HTH,
Tort
Really great photos! I own several good cameras, including a couple of nice digitals but can never get the cool "layouts" that make photos so interesting. All of my photos seem to be about as inspiring as the ones in a Navy personal hygiene brochure.
TortoiseAWD: Thanks for those links - very useful.
C240: I use an Olympus E-10, with the wide angle and tele extensions. Tkes me from about (in 35mm terms) 28mm to 200mm. More info at Olympus E-10
just wanted to chime in here carguy:
in my line of work i look at hundreds of photographers books and have worked with and supervised some very famous shooters (i'm an advertising art director). knowing that, i just wanted to say that some of your shots are just phenomenal. very nice work and great write up. your 996tt shot in the fog is really beautiful. keep that great stuff coming. :up
hopefully i'll have some pictures to show you guys in another month or so when i finally get my carbon black m3 cabriolet. :D
greg, just one more question. comparing the shots of the 996 vs. the m5, i'm wondering if the m5 shot shows the orange-peel so much more because of the low ap. is the paint on the m actually that much more orange-peeled than the tt? this is of particular interest to me because i assume my m3 will have paint quality similar to yours. i'm sure it's not bad at all. just curious if its a result of the camera's setup?
- jeff
if anyone ever needs any advice for photoshop, drop me a line. i'm a photoshop freak. it's also part of my job to retouch images. so if anyone needs a hand, let me know.
- jeff
Jeff - the paint on the M5 isn't nearly as bad as that shot makes it look. I think the door reflection is a better indicator. I think that particular shot just caught everything "right" to amplify the appearance of the orange peel.
The Porsche is marginally better, but it also has some.
Thanks for the Photoshop offer. I love Photoshop - and I'm OK with it, but I think you could learn new tings about it every day and never run out of things to learn! My son and I are planning to go to the Photoshop World conference in San Diego on March 15-17 to get some new skills.
