Not a problem, as I didn't think I was trying to sway or change your opinion in the first place.Mr. Clean said:We will just have to agree to disagree.
Because I have used a sponge and have seen the dirt & grime that accumulates on the surface for one. It has nowhere to go but the surface of the sponge. I don't see contaminants on the surface of the sheepskin mitt, so I am assuming that it goes "into" the nap. No scientific proof or anything, but I can see results and infer.Mr. Clean said:IMO this "migration" is only a theory which has been perpetuated on the detailing forums. It is (again IMO) a theory based on wishes and not fact. Once the chenille mitt or sheepskin mitt "grabs" a contaminant, I don't find that it moves up the fiber at all. But, if you choose to subscribe to this theory, then why not a sea sponge?
Rubbing in a general sense, yes. I prefer to softly "drag" my mitt in straight lines over the surface, but I guess any type of washing we do is actually rubbing the surface. No matter what you want to label what you do, you are moving something across the surface, therefore causing friction.Mr. Clean said:I'm assuming you didn't mean "rubbing". No matter the wash tool, I don't "rub" at all.
Because that's like comparing apples to oranges. You are washing to remove dirt & grit. You shouldn't be polishing a dirty vehicle. There is always a chance of getting grit on a polish pad, especially if you are careless with the polisher.Mr. Clean said:But speaking of rubbing. I have always found it ironic that some people love the sheepskin (wool) washing mitt and disparage the sponge (foam or sea), yet prefer a foam polishing pad and shy away from the wool pads while machine polishing, an activity which provides far more opportunity for surface marring if “grit” is introduced between the pad and the surface.![]()
I agree - unless you're using a Brillo pad. :lolMr. Clean said:If you are flushing your surface well with a pre-rinse, using an appropriate amount of a quality car wash, and using good common sense (rinsing your wash tool often, keeping the rinse water clean etc. etc. ) I see only a small opportunity for marring your paint’s surface no matter the tool you choose.
I am not trying to sway anyone either. I just felt like sharing my opinion. That's what the boards are for.Mr. Clean said:Unlike some, when it comes to detailing, I have no agenda, no need to sway anyone to my way of thinking. I have no desire to change anyone's mind about which car wash, polish, sealant, wax, drying tool, wash tool, etc. etc. etc. they choose to use. Frankly, I don't care what you use. A poll was formed and I offered my opinion. If you don't agree with me, I won't accuse you of being "condescending"![]()
Again, I agree with you. It's up to each individual to find what works for them. No one can tell them what's correct - they need to find it out for themselves. That's exactly why I choose not to use a sponge, dishrag, or brush on my finish.Mr. Clean said:I can only suggest that if any reader has been scared off from using a sponge by the doomsayers, then try one on your lower panels and be your own judge.
JeffM said:I use the sheepskin, but i dont like the wrist band. I am looking for just a sheepskin pad, that elastic stuff scratches....
