Which Swirl Remover would you recommend?
By hand or PC?
Hand - Scratch X.
PC - Detailers Pride Super Swirl Eliminator or Poorboys SSR 2 And 2.5.
SFX1 is quite abrasive. If swirls are light, first try SFX2 in conjunction with the SFX pad. This combo will generate enough heat to leave a crystal clear finish. Good luck :xyxthumbs
I haven't found a heavy polish that I like. A medium abrasiveness polish would be optimum compound. and for a light/finishing polish, menzerna's two ceramiclear polishes, po106ff and po85rd are awesome. these are by pc. Rotary may be different, but I dont own one so i can't really say what would work and what wouldn't work on it. by hand, scratchX is the only thing ive found to work.
It is also going to be relative to what you mean by swirls....machine induced?..micromarring?
Light duty...right now I would go with FPII..I believe that PO85RD WAS the best but it hasnt been manufactured in a year and will not be available unless you find someone with old stock somewhere. The newest version of 106FF will be here in about a month.
Meduim duty...IP
Heavy Duty..PowerGlos or OHC (?) optimums hyper compound
