I've been using a PC 7424 for about a year now and while I've loved the step up from doing everything by hand, I'm quickly realizing the limitations of the machine.
I'm going to start detailing professionally this spring. I like the safety of the PC since you wouldn't have to worry as much about damaging a customer's car. However, I feel it's too limited in what it can do, AND too slow at doing what it can do.
I've been reading all the press on the Flex, and obviously it's a major step up from the PC. However, I've seen several folks on the boards suggest that if you're going to upgrade from a PC or UDM, that you might as well go to a rotary.
So, would it be better to just make the jump to a rotary and learn how to use it really well, or better to go to the flex which will be better/faster than the PC, but not as risky as a rotary? I hate to shell out the cost of a flex, and then 6 months from now be wishing I'd gone rotary.
Also, If I go rotary, what's the most recommended machine? Makita?
Thanks for any inputs.
