Which Polish
Using a PC, and finding that you want something just a notch stronger from SMR, I have Finesse It (the one before they came out with before FI II), and I also have the 3M Perfect It Fine Rubbing Compound.
I also have a Meguiars Fine Cut Cleaner, and Griots Garage Fine Hand Polish.
Again, I want some thing for my PC...Do you think I have enough product to use, or, would you recommend adding on something like Griots Garage Machine Polish medium, or something else?
The old saying goes like this. Start with the least amount of abrasive and work your way up from there.
3M's F11 Fine worked very good on a 6yr. old minivan with a follow up of #9
Without seeing the amount of surface damage hard to really suggest what you may need.
we cannot see your car so we can't answer that question but Buldog hit it on the head.Start with the least abrasive one and work your way up.I have Groits Fine Hand Polish and I can tell you this is the polish you should use last.Griots makes 1.2.3 machine polish but the Fine Hand Polish is for swirl free paint.
