Dec 4, 2004 #1 L lazybum New member I have a PC with the Sonus DAS kit, should I use the 3m fine cut rubbing compound with the orange pad or the green pad? I'm trying to get out swirls i made by using 3m's swirl mark remover for dark paints with a crappy MF towel.
Dec 4, 2004 #2 L LouisanaJeeper New member cutting pad + fine cut polishing pad + fine cut followed by polishing pad +swirl mark remover you may be able to skip the first step depending on the severity of the swirls i dont know what colors your pads will be
