When to Replace Pads?
Reddwarf
First let me say I tried a new technique to clean my pads. After using them for a detail I squirted some PB APC in a bucket, added water and dropped the pads in the bucket to soak. I wish i had been diligent enough to measure the ratio. I let them soak longer than I planned, but I just did not have time during the week to make myself finish the job. Today I grabbed the bucket and I was amazed at the amount of thick goo (I assume wax/ polish) that poured out! I used some dish soap and hot water to clean the pads. It only took a few minutes and they seemed cleaner than my old process. PB APC soak is the way to go IMO!
On to my question. I have a could of pads with nicks. Overall the pad is worn and rough a bit with a couple of gashes. At what point does one toss out and buy new?
Thanks!
When it gets to that point, throw them away. When the foam starts collapsing, is not as dense, or becomes torn up, it's time to start with a new pad.
I would get a replacement pad but I would not throw it away just in case you needed an emergency spare.
