when to glaze?
imported_roadk
been detailing for quite a while now but,
never thought much of glazes....
when do you use glazes, why and what are the benefits/downsides?
thanks!
--roadk
I use a glaze as a final gloss enhancer prior to waxing. If your paint is in excellent condition, you should probably use a glaze every other time you wax to fill in any minor scratches and other light imperfections you pick up along the way. Use a stronger paint cleaner like a swirl remover every 4th time you wax and follow with a glaze. Clay as needed and your paint should look a mile deep for years to come.
Scottwax said:
..., you should probably use a glaze every other time you wax to fill in any minor scratches and other light imperfections you pick up along the way...
Hi Scottwax. You mean IHG?
I'm still confused that DavidB mentioned SG as a glaze in 'The Perfect Shine'. Is it a glaze in your sense?
IHG is good, I prefer Meguiars Hand Polish from their Body Shop Pro line, also Meguiars Show Car #7 or Machine Glaze #3 are also excellent.
IMHO though, Hand Polish is the easiest to remove, although Machine Glaze comes off reasonably easy also. You just have to remember to go light on glazes since they have a lot of oils in them.
The names can be confusing sometimes. ALL the products both 2wheelsx2 and Scottwax mentioned are true glazes in the traditional sense.
Klasse Sealant Glaze (SG) is NOT a real glaze, but a synthetic polymer sealant type of product. I suspect they used the word glaze because of its swirl hiding ability. Do not treat it like a glaze, and remember that sealants are generally not compatible over or under glazes.
Also (this confused the heck out of me as a newbie) Mothers Sealer and Glaze is just a traditional glaze. Ignore the word "sealer". :) I haven't used other glazes, but I find this product pretty easy to use, cheap, and easily available. Oh yeah, works pretty good too! :p
To add more confusion, Wax Shop's Super Glaze is a wax. :rolleyes:
I spoke to mayor David B the other day. Klasse SG really isn't a glaze. When using the All in One, a follow up coat of SG does make a difference but it's not well appreciated by everyday clients. On my own toys I'd use the glaze but not if folks aren't willing to pay for the product and labor. The wax coat over synthetic seals is key.
alright:
i use AIO and SG.
will a glaze remove the AIO or SG layers?
what will glaze do for me?
-- and what is your suggestions for a glaze best for black paint?
thanks!
roadk said:
alright:
i use AIO and SG.
thanks!
Yes, glazes will remove SG, hence what I said in my post above. AIO doesn't really "layer". Use glazes only with non-sealant systems.
roadk,
If you're using Klasse All in One and Sealant Glaze why do you want to use a true "glaze"? The other folks are right, a traditional glaze may contain cleaners that will strip your sealant. Just layer your sealant glaze a few times if you want better protection. For black shine the Souveran wax is key. When layered over your sealant it will be spectacular. Your Jetta is an Audi/VW paintjob, one of the best in the bussiness. Follow DavidB's perfect shine; clay, cleanse, spot clean with 3M Fine Cut Rubbing Compound, use 3M Swirl Remover for dark cars, Klasse All in One, follow with Klasse Sealant Glaze (layer this if you want) and top off with Souveran Wax. That's alot of work but if you maintain the car with quick detailing a few times a week, your work will last for up to a year. I detail a clients black VR6 with clay, Meguiar's Prem Paint Cleaner, 3M Fine Cut RC, #9 swirl remover, #20 Poly Seal and a final coat of caranuba wax. The guy is one happy camper. I just Quick Detail him a few times a month and he's good to go. Let me know,
Gil
