Just spent the better part of the last 2 hours using search to answer a couple of questions with mixed results.
Seems there are a number of great uses for a QD…The question is -- Is there a single "product" that will:
1. Act as a lubricant for a clay bar
2. Quick spray on a PC pad to help lubricate prior to the pad loading up
3. Quick spray on an applicator pad to lubricate
4. Assist in the removal of AIO
5. Use with the removal of and between coats of SG
6. Act as an occasional QD
Seems abundantly clear that products with Carnauba, other waxes and silicones are out prior to AIO/SG. Might this be better split into two products?
Thanks,
Russ
Thanks,
Russ
