Whats next
dynoman
Hello everyone,
I just purchased my Porter Cable DA what would be a good choice for pads for a beginner are the Edge pads good or is there something else that would be better?? Also what types of compounds or polishes would be good for starting out?
AutoGeek has a nice Edge kit for $99 right now. Can't really beat it to start up. It's nice to have 2 pads within one, but if it rips, you've just lost $18.
As far as polishes for a beginner using the PC, Poorboys is great. How old is the car you want to work on? Lots of swirls, oxidation?
I have a 2003 Grand Am--white and a 2006 GMC Pickup--burgandy. They both have nice paint with some light swirling. What type of poorboys polish would you recommend??
For PoorBoys Polish, I would go with either SSR1 or ProPolish, and apply either with a polishing pad.
"J"
Maxima, can you elaborate on your comments above? Why if you rip the pad have you lost $18? If you rip a single sided pad did you loose the $9-$11 per single sided pad? or do you just keep using it with the rip? If you tear the Edge2000 pad a little why not flip it over and use the other side? or just keep using the side with the tear? I am of course assuming the rip is not so substantial that it renders the pad usless. But if it did that kind of rip on a single sided pad you would have lost the whole pad, but on the E2K you just flip it and use the other side. I am not sure why you would loose $18? Can you clarify?
I guess if you rip it all the way through somehow, that's $17.99 down the drain. Not sure how you could tear a whole pad apart though... ?
