What type of Pads
fulldraw
I just ordered a PC 7424 and i was looking at the different kinds of pads to get. I am planning on just getting a starter kit to start with and then go from there. I have the edge starter kit for 69.99 and the CCS starter kit for 69.99. What are the pros and cons and basically which do you think would be best for someone starting out. Thank you for your time.
Both pad sets that you have are good. The edge gives you always centered pads, with easy on easy off removal. Plus you can use both sides.
The CCS pads are nice because they are a little more flexible then the Edge pads which tend to be more rigid. However I have found that the CCS pads work better on my rotary, they seem to really need the heat.
Again these are just my opinions, both pads are a good choice. And everything has its pro's and con's.
