What to use after megs 205
mkpedboy
So I've recently added megs 105/205 to my arsenal. My question is what should I use after the 205 before the Nuba/Sealant? I have been using meg machine glaze after 205, any more suggestions???
M205 is good for finishing, but it you just want a tad more sexiness, than 85rd and Ultrafina are the kings in finishing polishes.
I'm not *unhappy* with how M205 finishes on hard clear, but if I were doing something soft, and/or wanted the ultimate gloss, I'd burnish with something milder.
Menzerna FPII, 1Z ProMP, even an AIO with a tiny bit of cut. Probably 1Z HG too, if you know how to work it as a burnishg/jeweling polish.
If you stop at M205, I'd sure do the last pass(es) with a soft finishing pad though. With polishing pads, things can look OK under most conditions, but sometimes, *under very specific conditions* you'll see very light hazing.
I do 80% of my finishing with M205 and a black/gray LC flat pad. Works great for me on soft or hard clears.
The other 20% of the time I might have had to do some deeper cutting on harder clears with a surbuf pad with M105/PC. Then I will follow with M205/white flat LC.
A combo I've been really happy with via Flex is the the *Griot's* orange pad and M205. Just a tad more cut than the LC white but still finishes out as well. That Griot's pad is once again becoming one of my faves since I've started using it with the Flex 3401.
Is this the ProMP you were referring to?
I like what I get from UF with a blue LC by rotary. The PC seems to leave the same finish from what I was able to test, it just takes longer. I polished the whole door on my truck by rotary, than did one half of the door again by PC. It has been at least a year since then and I still cant see a difference in the panel under any light.
I have yet to try FPII or 85rd, but they are very famous around these parts.
scary bill said:
I like what I get from UF with a blue LC by rotary. The PC seems to leave the same finish from what I was able to test, it just takes longer. ..I still cant see a difference in the panel under any light..
That seems to be a paint-dependent thing..my experiences are that I can finish out the same with rotary/not (except for the holograms :o ) but others have different experiences.
That's pretty cool that it still looks the same (i.e., no new marring) after a year!
Yup. Another one to consider is Menz FPII, and also Optimum's new Finish Polish, although I haven't tried that one yet. If your paint isn't soft (like a Honda), you could also try 1Z Hoch Glanz. Very easy to use, but is best used on hard paint.
Same here, Bill. UF and FPII are the only two polishes that I can get to finish down perfectly by rotary on *really* soft paint. I've gotten UF and FPII to finish out holo-free on a black Bentley (softest paint I've ever done), a jet black BMW (second softest), a re-shot C5 (same softness as the BMW), and a Black Honda.
The really great thing about UF is that it has a lot more bite than FPII, and it's effective on hard paints, too. Sometimes it takes a second application of UF to totally clean up after compounding, but it is so fast and easy to use that a second application is no big deal.
Ditto. On very fresh clear (12 - 15 hours fresh).
+1 on UF on a blue 3M pad.
Some polishes seem to take away from that "as good as I can get it" look. M82 comes to mind. The only thing that UF would not finish down was the hood of the Honda CR-V. Nothing I tried would work. The paint seemed to absorb the oils in the polish and no matter how much polish I added ( it would sling like crazy too) the panel would be dry after 1 pass of the pad. I left some not so faint holos on the hood, followed with the PC and UF and the same pad to clean it up. Even the PC fought me :nixweiss
W/o uf I would ahve to finish w/a PC to keep my finish holo free. I like the rotary for a number of reasons, feeling in my hands being most important to me. Have you tried UF by rotary to see if you can finish 100%, I have a hard time beliving someone with your exeriance couldn't most of the time.
As far as the mar free goes, thanks. I have a very odd wash techique that works for me.:dance
scary bill said:
..W/o uf I would ahve to finish w/a PC to keep my finish holo free. I like the rotary for a number of reasons, feeling in my hands being most important to me. Have you tried UF by rotary to see if you can finish 100%, I have a hard time beliving someone with your exeriance couldn't most of the time...
No, I never tried the UF. And as I only do a few corrections per year, working to master finishing-by-rotary just doesn't appeal to me :nixweiss
Eh...I just finish out via Flex or Cyclo. It's just a personal preference of mine, but I simply don't like using my rotaries. REALLY don't like. Whereas the Cyclos are about as close to fun as this stuff gets for me.
On the "oils absorbed into the paint", I'm having issues with M205. Seems to take a *LOT* of IPA wipes to eliminate an oily haze that I can only see under my SunGun :think:
Oh, and I'm glad to hear you have your wash sorted out :xyxthumbs IMO that's the most important thing to master in the whole of detailing.
