what products to buy locally with nxt wax?
RonTL
im going to be buying the megs deep crystal 1 and 2, and im going to use them along with 2 coats of nxt wax. I want to buy locally, does the deep crystal 1 and 2 do a good job or should i buy other products locally? (wal-mart, autozone, napa) and is there a good wax to put over the nxt. I want some good prep products to bring out a nice reflective shine.
The Deep Crystal system is a very good consumer product. NXT is also a good consumer product for the money, just be sure to wait about 24 hours between layers for curing. Something I used to top NXT was S100. You could also use #16.
I use the deep crystal #2 then NXT and it looks great. I also clayed before I started. You need to make sure that they surface is real clean first.
I have used Meg's Deep Crystal system in th past and it's really very good -- especially for a consumer product. I've also followed Deep Crystal products with NXT and obtained good results. If want to top NXT with something, I've used P21S with good results -- as long as you wait to apply it.
You can get S100 wax to top the NXT locally at a Harley Dealer. You could also pick up SEPC at the Harley Dealer and use that instead of Megs Deep Crystal #1 and #2. You could also use Megs ColorX before the NXT Wax. You should be able to buy that were you buy NXT.
There are a lot of other products you could use that can be purchased at the stores you listed.
Mothers 3 step. Should be able to purchase these at Walmart and Auto Zone.
Megs #26, #20, #16, MPPP, MMPC. You should be able to purchase at Napa.
THanks for all the reply's, ill probably buy some #9. THen ill wash/clay/wash/#9/nxt.
then i might buy some deep crystal 1&2, and try it.
So the #9 will do a better job than the DC 1&2?
i think the
wash
clay
#9
NXT
would be better than the DC 1 and 2.
If you want to add more shine before the NXT than go with megs # 7 after the # 9 :xyxthumbs
instead of doing the #9/nxt
would izpp/nxt be better
I have some swirls and minor scratches i want to get out, and i will be doing a this by hand, so i want something that works good with hand, and does the izpp or izmp leave a great ready to wax finish, or should i just do the #9/nxt.
DC 1 & 2 are non-abrasive. #9 has a bit of cut to it to help remove light swirls. Using the clay, then DC 1 & 2 before the #9 will help make sure your finish is completely clear and ready for the #9
