What Product with what Propel Pad!!!
impulsebrklyn
Ok I have the whole Propel Kit and a few extra of the ones I will be using more off.
Pads in order of least to most agressive
Grey
Blue
Green
Yellow
Orange
Products I need to match with the right pads
Poorboy's SSR1
Poorboy's SSR2
Zaino Z2 Pro
Zaino Z5 by machine????
Im assuming the SSR2 will be used with multiple pads higher then the pad for SSR1 depending on the amount of cutting needed. Where would you start for removing moderate plus marring and some minor swirls.
Thanks Chris
Don't know much about Zaino with PC.
SSR 2 can be used with any pad up there besides the grey finishing pad. It will perform on different levels depending on which pad you use.
SSR 1 can/should be used with either the blue or green pad.
Zaino with the grey or the blue?? Grey to finish or blue to finish with the slightest cut? Anyone have any expereince with Propel and Zaino??? Chris
Zaino and grey....but it uses ALOT of product and soaks most of it up. You're better off applying it by hand with a MF applicator. I made an ounce of it today and put 3 coats of Z5 with 1/3 of an ounce still left.
I would get some ssr2.5 as I use this for all most everything. Ssr 2.5 can be used with the green, yellow and orange pads. When used properly with the green or orange there is no need to follow up with anything else, go straight to lsp. Ssr 2.5 is my go to polish.
