What is the one light/lamp you can't live without?
peacemaker
I'm currently trying to figure out if I'm going to buy a spotlight or a headlamp. I was curious to know which would be more useful to the weekend detailer.
So which one can't you live w/o?
I can't really narrow it down to *one* light as IMO there's no single (type of) lighting that adequately covers al the bases.
If you were me, the weekend detailer, has a white car, so will be operating in a low light environment garage, which one would you have on hand?
I like the brinkman bc of its versatility and price point... I like the Fenix HP11 for its functionality/usefullness. It stays on my head, it has several brightness modes, and I can constantly monitor my work without having to drop the tools.
Honestly my one light would be my halogen lights. You can set it bac to light up the car bright enough to work on an hold it up close to check for anything that needs to be corrected yet.
I've found this 5000K single diode LED to really show the swirls on most colors EcoSmart 18-Watt (90W) Day Light 5000K PAR38 DayLight LED Light Bulb (1-Pack)-ECS 38 CW FL 120 at The Home Depot You may have trouble finding this exact bulb so just look for a single diode, 5000K, 90-100w equivalent LED--I know Lowes has a couple.
In order to make it easy to use I found a photo light stand and socket for about $18 including shipping--
On some light colors I'll use a 6500K 100W CFL in the stand--it's allot like the lights at the gas station at night that seem to show up every little flaw.
Shane--Here's the stand ::: Best Seller! Juliusstudio.com ::: Top Quality Aluminum Alloy Adjustable Light Stand and the socket ::: Best Seller! Juliusstudio.com ::: High Quality AC Swivel Adapter, Light Socket - Accessories - Continuous Lighting
The LED weighs 1.5 lbs and the socket perhaps 1 lb--the stand is rated to handle 5 lbs, but with the LED bulb it is a little top heavy so I throw a small sand bag over one of the support rods just so I don't knock it over. They also have a socket that will hold 2 bulbs, but then you'd need to get one of their heavier duty stands.
Won't go anywhere w/o my Brinkman. I've had issues seeing the real deal under halogens on some paints. Just doesn't look deep into the paint enough. More or less bleaches certain defects out.
If I just hol it straight up to the paint it will flood out defects usually, but if I move it around and look at different angles it works good.
If you can find 4300k bulbs that would probably be the best bet as it's the closest to daylight color and the brightest in the spectrum. If you go higher try get bluer and lower yellow I believe. 5000k is damn close though.
Husky at home depot.
This one and two of the smaller ones are working for me. I also wear a ledlenser h7r so I can see what isn't covered by the other three. The best situation IMHO is where you have no indirect light. Contrast shows flaws, indirect lighting is like a cloudy day.
Robert
Noting that I do have a white car, for an "only one" light to spot marring, I'd probably go with my incandescent trouble light.
BUT...I haven't tried LEDs yet, and that might work just as well.
BUT#2, IMO everybody oughta have at least one halogen work light. You can find 'em on sale now and then at prices that are pretty reasonable.
Yeah, I am going to try to get my hands on at least one of those for my next detail. I used one last time, it was very useful. A stand would make a big difference.
They're 11.97 at wal mart. No reason not to have one or 2. At that low of a price you should be able to get one for a work light then another light that's better suited to seeing imperfections.
Oh yeah, halogen work lights are super cheap, easy to find, and easy to find replacement bulbs for. Perfect for the weekend warrior IMO.
And ya know... just FWIW, my cheap one (total POS that's gotta be thirty years old now!) somehow shows marring better than my "good" one from Sears. Just some diff in the reflectors or something.
