SwedishRider
I'm trying to calculate the extension cord gauge needed for the GG6 I just purchased. The specs of the tool are listed as follows:
Motor: 7 Amps, 850 Watts
Power Supply: 120 Volts, 60 Hz
And the tool already has a built-in 10' cord (18AWG) that will obviously not be long enough by itself for use.
The breaker that feeds the outlets in the garage that I'll be using is 15A. Is there a calculation or rule of thumb that I can use to determine the gauge needed (preferably based on feet of cord away from the outlet)? I would think that a 25' extension cord would be ideal, making for 35' of total length to be typically used in a garage bay (but I'm open to other suggestions if others feel differently). I have no idea the distance of the garage outlets back to the main house panel.
Thanks!
Thanks!
