Jun 18, 2010 #1 B BluBrett New member I keep getting buffer hop on doors and fenders. What technique do you use to perfectly polish a door, especially at the lowest areas?
Jun 18, 2010 #2 J jono20 New member A porter cable . I always keep it around for the low visibility areas that are hard to get at with a rotary.
Jun 19, 2010 #3 F FastEddysDetail New member Get down and level with the surface, keep the buffer flat, and you could you water or a Qd to keep the product from drying up and skipping.
Jun 19, 2010 #4 lasthope05 New member Keep your pad clean, and well lubricated. You get buffer hop from either the pad being dry or being gummed up with spent polish.
Jun 19, 2010 #5 B BluBrett New member It probably doesn't help that I am trying to do this with an 8 inch pad . Thank you for the replies, if I see any holograms tomorrow I'll retry with your advice.
Jun 19, 2010 #6 J jono20 New member I use 7.5" curved pads on a 6" backing plate, and 4" flat pads on a 3" backing plate with my rotary Smaller is usually easier to control, and the edges are spinning slower so it's less dangerous.
