what did i do wrong?
jimbo_01
i finally got around to trying the blue PwC and blue Natty's on my truck. when removing the products the majoraty of it buffed off easily but there was a couple of places where the products left little lines and i had to buff them pretty hard to get them off. do you think i didn't leave the products on long enough? i probaly waited around 5 minutes after applying them before i removed them. it was also around 85 outside with high humidity.
thanks for any info
were u in the sun....it may have dried to much. if it was in the shade it shouldnt do that where u would have to buff really hard. if it happens again somtimes if u spray some detail spray or spray and wipe it may come off alil easyer.
is it okay to use a detail spray on fresh wax to remove it? i thought you had to wait for the wax to cure before you put anything on it. if it's okay to use it which should i use? i have spray and wipe, spray and gloss, and some meguiars final inspection.
well you shouldnt have to but if u are in a spot you can. its not bad for it but again maybe the car was to hot and it dried to fast. it should just wipe off and you shouldnt need to use spray and gloss but it helps if it does happen
