Todd@RUPES
Just a regular guy
After washing and claying your vehicle it is often a good idea to mask off certain parts before machine polishing. Machine polishes and pads are designed to work on automotive paints and gel-coats and can damage or stain soft rubber trim, plastics, rubber and vinyl convertiable tops. Additionally sharp emblems can tear and damage polishing pads as the spin over them.
It is better to take the time and tape everything that can be damaged by the machine polisher then risk the consequences of permantely damaging trim. Taping areas that are very difficult to clean dust out of can also save time in the long run.
First wash and dry the vehicle thoroughly. Inspect the paint for a rough feel and contamination. If the surface is rough to the touch use detailer's clay prior to polishing to restore a smooth feel.
Attach low tack tape firmly to an edge of the trim.
Holding the anchor point, unroll the approximate amount of tape needed to cover the piece. Pull the tape taunt.
Use the hand holdling the roll of tape to guide the piece as your press it into place with your other hand. Take your time and try to mask as accurately as possible to reduce clean up.
After is complete remove tape prior to washing.
Remember that 2 minutes of time and 2 dollars of tape would have prevented over $4,000.00 dollars in damage to this Lambroghini!
How To Tape
