WG sealant - dusty?
Casebrius
I just did a job with 2 coats of WG sealant on a black Marauder (ssr2.5 then AIO prep). It looked great to an untrained eye, however there was a small amount of smearing I couldn't remedy in the time alotted. It was applied in a VERY humid environment which may have contributed to the smearing (90degrees/90% humidity). The WG was let set for about 8 hrs before removing the second coat. I'm also curious if the 2 coats of WG combined and created too thick of a coat. One complaint was that it did seam to be a dust magnet. Maybe thats just black in general because it shows EVERYTHING, but has anyone else noticed a dust attraction? Also, a word of caution to anyone who might detail a Marauder, I've heard from other people and there were signs on this car that the paint was very thin.
It's static and goes away with first wash, happens a lot of the time. Try using different type towels to remove residue, MF seams to bring this on but I've heard other towels might keep the static away. Wolf is so easy to remove you don't need MF like you do with most other sealants for easy removal.
